Injector? 300 Straight 6 - Ford Truck Enthusiasts Forums
Old 02-12-2010, 05:24 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Could this sound be caused by an injector?
Old 02-13-2010, 01:10 PM
No body has an idea?
Old 02-13-2010, 01:27 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Cant tell anything from the video , whats it doing ??....Lew
Old 02-13-2010, 07:16 PM
It's making sort of a skiping sound on the passenger side of the engine.
Old 02-13-2010, 09:00 PM
fishforlife2007's Avatar
fishforlife2007 fishforlife2007 is offline
fishforlife2007 is starting off with a positive reputation.
have you pulled plugs and compared them.? that mite give you some insight.
Old 02-13-2010, 11:41 PM
Gave it a full tune up last week, had some fairlly new ACDelco plugs on it, I putted 6 new Motorcraft plugs, wires, rotor and cap.
Sound hasn't changed after tune up.
Old 02-14-2010, 12:24 AM
i was more referring towards whether or not there were any deposits, or indications on the plugs showing that there was too much fuel, going lean, etc. im sure the gap and everything is ok since you just changed them out, but you might be able to figure something out on this issue if there are any deposits on them. ive got a tool that i bought off the Matco Truck up at work that will tell you whether or not a injector is actuating like it should, and lights up if it is functioning right, and stays non lit if it isnt. its just called a injector tester. not sure if you have access to one, or if you can rent one, but that will tell you if you have speciffic injector problems, or whatnot.
Old 02-14-2010, 08:23 AM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
Could be a exhaust leak, kinda hard to tell in the video. But I don't see any engine rocking that would indicate a dead cylinder. Does the engine twitch in sync with the noise? Another way to verify is to pull spark plug wires off one at a time then back on to see any changes in how the engine runs. If you pull one wire off a missing cylinder, there will be no change in the engine.
Old 02-14-2010, 09:14 AM
hotrod351's Avatar
hotrod351 hotrod351 is offline
hotrod351 is starting off with a positive reputation.
from what ive seen on the tv programs you should be able to use a probe, a piece of hose, and listen to each injector and hear it clicking on and off. also if you had a bad injector you should have a miss.
Old 02-14-2010, 11:52 AM
Quote:
The ACDelco plugs that were in it, were great looking and gold coloured witch means it's running with the right mixture.
I've never heard of a injector tester, I'll have to look into it.
Old 02-14-2010, 11:56 AM
The engine does run fantastic, doesn't shake or anything. Only wants to stall when you hit the throttle hard parked, let off and hit again and it's fine, revs up no problem. I've heard alot of guys here had the same problem and it could be many things. I'll leave it be, as long as it doesn't do it while i'm driving.
Old 02-14-2010, 10:31 PM
Old 02-14-2010, 10:49 PM
Thanks alot
Oilburners IDI weekend Pics/Vids IDIDieselJohn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 08-17-2015 04:42 PM
New Shaggin Wagon! IDIDieselJohn 1968-2013 Full Size Vans 18 03-24-2014 01:34 PM
The Winter Truck! IDIDieselJohn 1987 - 1996 F150 & Larger F-Series Trucks 19 12-08-2012 09:20 PM
Yard sale anyone? IDIDieselJohn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 09-14-2011 08:04 PM
Custom Built '88 F350 4x4 Step Side Dually + NEW PICS of crazy invention! IDIDieselJohn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 34 12-11-2010 02:25 PM
Tags
1987, 1989, 300, 90, alba, bad, engine, f250, ford, fuel, jessica, liter, mileage, ord, straight, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
