Poor fuel mileage
I was checking out the electric fuel pump post and in the first pic where the 2 metal lines go into the brass looking fitting is right around where i was seeing some fuel smelling moisture. Is there something under the IP that could be leaking? If so can i simply remove the injector pump and take a look? I've never removed one of those before. Thanks!!
The sensor that detects that the filter is fouled is a known weak spot for a leak. There is a cheap way to over come that leak if you need it we can supply more detial. There is another filter insdie the chamber where the dirty filter sensor is attached. Check out this thread for more:
https://www.ford-trucks.com/forums/9...-problems.html
I read a thread recently where someone pulled their injectors and soaked them in PowerService Diesel Kleen (gray bottle) for about 10 minutes.
I've also read of people filling the fuel bowl with Diesel Kleen, putting a filter (in your case new filter) back in and taking off. Should get the injectors nice and clean. I just started running Power Service (white bottle w/ anti-gel). I didn't notice a huge difference in mileage, but the engine did seem to idle a bit smoother. Increases in mileage this time of year are hard to track with the temperature swings.
Michael
Michael
Living in a cold climate for half of the year, I can say that cold has a BIG impact on mileage. I've seen my mileage plummet from almost 18 to as low as 12. I continue to debate whether I want to order a 203* stat from Dieselsite. The last time I tried to change my stat, I cross-threaded a bolt and ended up snapping the head off it. The new water pump with later set me back about $600 that I was not expecting.
#30
