would that make it chug like a chu chu train out the oil cap ???????
Dunno, but unless it blew the cap off, I'm not convinced what he saw was all that bad. I freaked the first time I looked at mine, but the cap sits on there just fine:
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid370.photobucket.com/albums/oo148/Izzy351/CCV_3.flv">
But they are two different problems right? Yours was a tick tick tick and his was just a BOOM.
Mine would have been a boom shortly IMO.
The compression on my old engine was better than the new one that I have in there now. I can tell that by the way that it runs cold in the morning. It won't diesel clatter and it billows 5x as much fuel smoke unless I drive it and heat up the combustion chambers.
The problem with mine was a mechanical knock knock knock knock that was audible on decel, injectors shut off.
Only thing that does that is a machining tolerance that has gotten too big and things are starting to slop around.
Whatever was going on was below the rings in the rotating assembly somewhere.
Now on Superduty's engine, his symptoms are much different.
The definate engine miss and the chuff chuff chuff out of the oil filler cap can only mean one thing - loss of compression past that piston.
The engine miss is happening because these engine are compression ignition and without compression because of the melted piston = no ignition.
