High Torque Starter
High Torque Starter
After reading the following thread...
https://www.ford-trucks.com/forums/8...wing-down.html
I ordered a high torque starter from DB Electrical. Noting one of the posts which mentioned the difficulty to install, I have a follow up question. Do you consider the starter to be sufficiently mounted since there are only two mounting holes as opposed to the three on the OEM starter?
thanks,
Rory
thanks,
Rory
on
1 Post
There are two forces on the starter.
One is the counter force from the flywheel. That force is borne by the ring.
The other is the starter wanting to spin around itself due to the torque on the pinion. That moment is carried by the bolts. But given that no one has reported it breaking it must be OK.
i just put my db starter in about week or so ago, mabe 2 weeks and it took me 45 mins taking the starter out, putting in the new one. the back bolt took me no more than 2 mins to get out, just get a lon g extension to extend longer than the starter and you have just enough room to get to it. the starter when back in and bolted up clean, for being made in china its some quality stuff. sounds way different starting thoe, almost like a dodge? but very quick
Well to make someone feel good, I had to drop my starter to rebuild it (It was fun, easier then those old starters) but I came to found out there were only two bolts holding mine on. And the ring gear and the starter pinion gear were both fine.
on
1 Post
How long does it take to wind down? I've noticed other reduction gear starters spin quite a while because they roll so fast. Kicking it back in too fast will make it grind.
My truck is being overtaken by Chinese parts!
DS
I am going to bump this thread. My DB Electrical Nippon Denso "style" starter has been failing the last two weeks. It left me stranded during a snowstorm last week. Argh. I had reservations when I installed the thing. I had thought it would be a Japanese part, but it had a big Made in China sticker on it. According to Wikipedia, Denso outsorcesd some manufacturing in 2002, so the quality is suspect in my opinion.
It looks like DBE should honor the 1-yr warranty, but it's still a pain to R&R the thing and ship it back. I put the old one on, but I need a new gear reduction starter. The slow crank sucks!
What are the options for g/r starters? Mitsubishi? The other vendors I see are:
Beck-Arnley - Chinese?
BesTest - Chinese?
Ultima - O'Reilly's - Chinese?
AC-Delco - Mitsubishi?
Motorcraft - ?
Bosch - Mitsubishi?
Remy - ?
Here's a link to O'Reilly's page for 1997 PS Starters (not all are g/r starters):
List: Starter - 1997 Ford F-350 | O'Reilly Auto Parts
All of these appear to be remans except for the Ultima and one Beck-Arnley. I am okay with a reman as long as it is reliable!
Rockauto has Remy and Denso versions. I would presume the Denso is now made in China.
Please don't call me a xenophobe or anything. I just don't want to put inferior quality parts on my truck. It needs to be reliable and in my opinion Chinese automotive manufacturing has not risen to a level that I can confidently rely on.
I would appreciate any help or experience anyone can offer. Thanks.
DS
BesTest - Chinese?
Motorcraft - ?
Bosch - Mitsubishi?
Remy - ?
DS
This is the one i put in mine it's for a 02 Super Duty it's been in for over a year and no problems
http://www.oreillyauto.com/site/c/de...1920&ppt=C0330
DS
DS
I've seen what I think is called the denso super starter for the 7.3 from 88 -03. It's huge and has lots of guts. The only disadvantage is you have to cut out a little of the crossmember under the engine. This thing sounds like a 18 wheeler when it spins over. It's kinda pricy though or I'd have one on my truck.
