HVAC blower wiring schematic - Ford Truck Enthusiasts Forums
Old 02-10-2010, 01:48 PM
chuckers98 chuckers98 is offline
chuckers98 is starting off with a positive reputation.
My 1995 Ford motorhome blower does not work. The motor works fine. All threads say to follow the circuits to troubleshoot. That is nearly impossible with wiring harnesses. I need a Ford F- Series HVAC wiring schematic to find ALL of the electrical components, in order to test. Please help.
Old 02-13-2010, 10:47 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Here is a cut down part of the Denso Blower circuit:
Old 02-13-2010, 08:59 PM
Blower motor relay
My 35' Pace Arrow is built on a 95 F53 460 Chassis. It does not appear to be the Evans HVAC system. I have purchased three separate ford wiring diagrams. The all show completely different color codes. My system 12v main power to the hvac system is Blue wire w/ red stripe. It goes directly to the Blower relay pin #87. The blower motor has one blue wire and one blue w/white stripe. All of the wiring diagrams show brown/orange and orange/black wires. I am gettin very frustrated.
Old 05-13-2010, 03:31 AM
r14tier r14tier is offline
r14tier is starting off with a positive reputation.
01 f150 5.4 engine blower inop
please help with schematic to ac system relay good behind dash, resistor looks good and have power to blower motor
Old 05-13-2010, 03:33 AM
blower not working at all
Old 05-13-2010, 07:03 AM
subford's Avatar
Here it is:
Old 02-23-2015, 02:15 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.vettdvr is gaining momentum as a positive member of FTE.
Pin 85 and 86 on my 2000 7.3 Excursion have power all the time with key off energizing the blower relay running the batteries down. With the key on I can turn the blower off. Apparently the switch panel is getting power with the key off as the flow of power has to go through the switch. Switch off key off a few seconds later the blower starts up. I have the blower unplugged each time I park the truck. Any suggestions/help? Where is the blower high relay located I have no manuals and havent' been able to find it.
Old 02-25-2015, 08:09 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Please keep information in your other thread instead of resurrecting an old, dead thread and posting about the same problem in multiple places.
2011 F350 6.7L heater fan issues?! Oregon04SD 1999 to 2016 Super Duty 5 11-22-2016 05:17 PM
Blower Fan Intermittent Usaman 1999 - 2003 7.3L Power Stroke Diesel 3 11-10-2016 09:31 AM
I am looking for 1948 wiring information mrstude 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 09-16-2015 10:13 PM
How to replace power distribution box relays? SweetBearCub 1968-2013 Full Size Vans 3 07-30-2015 06:04 PM
Dealer Installed A/C Questions 86-IDI 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 03-08-2015 07:14 PM
Tags
1999, 2004, blower, company, dash, f53, ford, hvac, motor, schematic, switch, truck, wiring, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
