seat belts stuck - won't unlock - help please - Ford Truck Enthusiasts Forums
Old 02-10-2010, 11:35 AM
jason86's Avatar
jason86 jason86 is offline
jason86 is starting off with a positive reputation.
Question seat belts stuck - won't unlock - help please
Just bought a '92 Explorer and the seat belts on the passenger side won't unlock. Any ideas?
Old 02-10-2010, 12:54 PM
shorod's Avatar
shorod shorod is online now
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Are the passenger seat belts pulled all the way out and won't retract, or are they stuck in the retracted posititon?
If stuck all the way out and won't retract you might be able to access the retractor to find that the pendulum is wedged in a cog but the belt is out so far that you cannot pull it enough to unseat the pendulum from the cog. If you were to pull the belt out has hard as you can, then have someone release the pendulum from the cog the seatbelt may one again function properly. I've had this happen on two separate Fords of similar vintage to your Explorer. The first was in my first car, a 1988 Escort EXP. The belt was that way when I bought it in 1990, I did the above and it never acted up again for the 9 years I owned it. The second time was in a 1993 Taurus SHO which happened while I owned it but only the one time.
-Rod
Old 02-10-2010, 01:59 PM
jason86's Avatar
What I meant is the that the latch won't release.
Old 02-10-2010, 07:04 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Quote:
I had that happen to me in an Explorer right after I bought it. There was some trash or paper lodged inside and I had to get kind of forceful with the button, it did free up and I didn't have to break it, after cleaning it out it has caused no problem
Old 02-10-2010, 07:29 PM
jason86's Avatar
thanks, I'll try that. How did you clean them out?
Old 02-10-2010, 10:39 PM
Moto Mel's Avatar
I had to improvise with long needle nose pliers, a pick and a knife, It was just paper and assorted trash.
Hubs won't unlock 2002exPSD Excursion - King of SUVs 1 08-26-2016 06:42 AM
Seat Belt homertwo 1999 to 2016 Super Duty 0 06-03-2016 12:03 AM
power locks won't unlock kaz442 1968-2013 Full Size Vans 10 01-11-2012 11:49 PM
'Adjusting' Seat Belt Mechanism? Munkey 1999 to 2016 Super Duty 7 11-03-2007 01:23 PM
Driver-Side Seat Belt Won't Retract Donato 1999 to 2016 Super Duty 3 06-03-2007 05:57 PM
Tags
2003, 2010, belt, belts, explorer, f150, ford, retract, seat, seatbelts, stuck, truck, unlatch, unlock, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
