New 2-Wheel drive leveling kit on ebay
Old 04-24-2011, 05:33 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
I wonder if my newer Bilsteins have more travel than the old ones.
I can jack up my front end and let the tires hang down and there's quite a bit more travel on the shocks than an inch.
Stewart
  #62
Old 04-24-2011, 06:27 PM
F350-6's Avatar
F350-6
F350-6 is offline
Have you got the blue and yellow ones or the silver and black ones Stewart? The 5100 series (silver and black) are made for trucks with a lift so that might explain it.
Or maybe my truck just likes being difficult.
  #63
Old 04-24-2011, 11:09 PM
Stewart_H's Avatar
Stewart_H
Just the standard OEM replacement series shocks. The blue and yellow ones.
Stewart
  #64
Old 04-25-2011, 06:52 AM
izzybird's Avatar
izzybird
izzybird is offline
I noticed my blue and yellows were too short when I installed them also. My truck may be 4x4, but I had the same shock issue. At full suspension droop I'm past the point of shock travel, no lift on truck. I was irritated by the fact but since I'm 12 miles from civilization, I installed and have been running them since. Wonder what gives.?
  #65
Old 04-25-2011, 07:17 PM
BadDogKuzz's Avatar
BadDogKuzz
BadDogKuzz is offline
Originally Posted by Franko72
My shocks seemed long enough when Roland and I did my leveling kit? (not sure what brand they were)
I just recently replaced them (4 months after the leveling kit) with some Reflex's. While the swing arms were fully extended down I had no problem bolting up the shocks...I didn't make a point to look at the length, but IIRC they were fully extended when I bolted them up. So I'm guessing they were "just long enough"
Frank, I see you used the Reflex / shock I had just put them on the back of my truck in Dec. and am going to install them in the front with or without level kit this summer. I am still not sure I want to lift it. That I am waiting until I have the coin to do ball joints and bushings. So how do they ride?? Also I remember you had a little issue when towing. Did you get that worked out. If so what did you do to get the truck to handle better with a load ?
  #66
Old 04-25-2011, 07:47 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
Actually the shocks that I removed were in good shape, I just wasn't sure how old they were. (they were on the truck when I bought it.)
The reflexes are doing what they are supposed to be doing. They seem to recover faster with a load than the older shocks.
I'm happy over all with em, but My front end is still a little squirrly when I have a lot of trailer tongue weight. I guess thats normal without a WD hitch.
  #67
Old 04-25-2011, 08:12 PM
BadDogKuzz's Avatar
BadDogKuzz
Thanks Frank. I was thinking if I go with the leveling kit I was going to go with air bags when towing. But I am looking forward to putting the reflex shocks in the front due to the fact that when I am on the highway the front gets alittle loose when I hit a dip in road.
But as far as the leveling kit it does help the total look of the trucks. Your truck is proof !! It is cool .
  #68
Old 04-25-2011, 11:08 PM
gtnwood's Avatar
gtnwood
gtnwood is offline
I also have this kit installed thanks to Franko, and once I got the cam kit installed it rides like a dream.
  #69
Old 04-27-2011, 08:39 PM
BadDogKuzz's Avatar
BadDogKuzz
When you guys install the cam kits for camber how many degrees are you needing from stock? Also seen kits that do both camber and caster. Have any of you had caster issues with the 2 inch lift? And how good where the front end spec's after alignment?
  #70
Old 04-27-2011, 08:59 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
I dont know, yes mine do both, No, and I'm not sure... I had an alignment shop do the dual axis camber bushings when they did the alignment.
All I know is it looks good, and it goes down the road straight.
tomas428
04-13-2022 04:10 AM
nathankershaw
Vehicles for Sale
11-18-2016 09:26 AM
mizzitch
Minnesota Chapter
69
10-02-2016 03:28 PM
chloichina
05-13-2010 02:17 PM
Danger_Dave
20
04-20-2010 06:00 PM
Quick Reply: New 2-Wheel drive leveling kit on ebay
