Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
New! Use your Facebook to securely log into this site, click logo to login
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-09-2010, 07:24 PM
rmeyer001 rmeyer001 is offline
rmeyer001 is starting off with a positive reputation.
Instrument Cluster Change
Hi, I am new to fourm. First post, but have used the forum alot in the last few weeks. Thank you for all your posts.
About a month ago I bought a 94 F150 XLT Supercab 4X4, shortbed, 5 speed, 5.0, 3.55. Since purchase, I have replaced steering box, water pump, front brakes and rotors, Drivers ball joints, front axle ujoints, front driveshaft ujoints, rear speed sensor, and rear parking brake cables. I would like to replace the factory instrument cluster with a factory one that has a tach in it. Is this a simple swap as long as I get a 94 cluster, or what other years will work. I am not worried about the odometer not matching my current numbers, but I would want it to work. Also I am assuming that Ford did not change the wiring between tach trucks and non tach trucks, but I would like to see if anyone has any info or experience doing this. I have searched the forum about this, but have not found anything concrete. Thanks for the help.
  #2 (permalink)
Old 02-09-2010, 09:01 PM
TexasGuy001's Avatar
TexasGuy001 TexasGuy001 is offline
TexasGuy001 is gaining momentum as a positive member of FTE.TexasGuy001 is gaining momentum as a positive member of FTE.
Welcome,
Its an simple swap. Just make sure you get a 94 or 95 cluster.
__________________
1995 F-150 XLT 2WD 5.0 AODE (4R70W) 3.55 LS
1965 Mustang 302 T5
PICTURES AND INFO IN GALLERY
http://www.youtube.com/watch?v=KF7soIRbh9M
Texas Chapter
  #3 (permalink)
Old 02-09-2010, 09:07 PM
ichabod40 ichabod40 is offline
ichabod40 is starting off with a positive reputation.
This should help...
Installing An OEM Tachometer In A 1992-1996 F-150 Or Bronco .: Articles
  #4 (permalink)
Old 02-09-2010, 09:20 PM
Thanks for the quick reply!
  #5 (permalink)
Old 02-12-2010, 02:15 PM
I swapped cluster with one out of a 95. All lights and gauges work but tach is dead. I checked fuse #17 which is suppose to run chime and tach and checks good. Any other ideas?
Thanks.
  #6 (permalink)
Old 02-12-2010, 03:13 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
some years don't play nice with other years.
best to get a 94.
__________________
"To believe is to know you believe, and to know you believe is not to believe." ~ Jean-Paul Sartre
  #7 (permalink)
Old 02-12-2010, 03:48 PM
Nevermind. I did not have the one wire bundle completely snapped in.
I guess I thought it was wireless.
  #8 (permalink)
Old 02-12-2010, 08:05 PM
Thats good that it works now.
__________________
1965 Mustang 302 T5
Texas Chapter
  #9 (permalink)
Old 02-13-2010, 05:56 PM
brian_06328 brian_06328 is offline
brian_06328 is starting off with a positive reputation.
[/quote]I guess I thought it was wireless.[/quote]
That made me laugh
I want to do the same swap, but can't find a truck in my area that isn't completely gutted or has the same cluster I already have. Did I understand from some of the other threads on this that as long as you change out the psom to the new cluster the odometer reading stays the same?
  #10 (permalink)
Old 02-13-2010, 06:25 PM
quicklook2's Avatar
read the linked file from earlier post.
__________________
  #11 (permalink)
Old 02-13-2010, 07:52 PM
subford's Avatar
subford subford is offline
subford has a great reputation on FTE.subford has a great reputation on FTE.subford has a great reputation on FTE.subford has a great reputation on FTE.subford has a great reputation on FTE.subford has a great reputation on FTE.
brian_06328 wrote:
"Did I understand from some of the other threads on this that as long as you change out the psom to the new cluster the odometer reading stays the same?"
Yes it does.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #12 (permalink)
Old 02-13-2010, 07:58 PM
fishforlife2007's Avatar
fishforlife2007 fishforlife2007 is offline
1995 Ford F-150
fishforlife2007 is starting off with a positive reputation.
did it on my truck... took about 30 mins, and besides my locking hubs, this is my favorite upgrade to the truck...
__________________
FORD......Found Off Road Diggin......
Quote:
Originally Posted by 6CylBill View Post
The only way this Bronco could get any better is if Jessica Alba and Lindsey Lohan made love and waxed this Bronco with their combined love juices.
1995 F150 Flareside w/ six cylinders of fury, 4x4 and leveled out with BFG 31's
  #13 (permalink)
Old 03-17-2010, 03:21 PM
lasitter lasitter is offline
lasitter is starting off with a positive reputation.
Quote:
Originally Posted by ichabod40 View Post
Between 1995 and 1996 there are wiring differences in the cluster, such that the ABS stops working / light comes on if you use a 1995 cluster in a 1996. That's what happened to me after I read this article and others told me that it "should" work ...
__________________
1996 F-150 XL Std Cab Long Box 4.9L, ZF-S542
Tags
1987, 1996, 96, bronco, change, changing, cluster, dash, f150, ford, instrument, insturment, truck, trucks, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
