Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-09-2010, 06:38 PM
jeffdoerr jeffdoerr is offline
jeffdoerr is starting off with a positive reputation.
trans temp gauge sensor placement
I am putting in an Autometer trans temp gauge, Phantom series. Ordered the gauge and it come with the gauge head and a sending unit. No fittings, no adapters, nothing. I want this in the HOT side and as close to the trans as I can without being stupid and anal about it. The truck has had transmission issues and this is the 3rd transmission I have put in it. The driver hauls heavy loads and keeps cooking stuff. Just to see if it would work, I installed a T fitting at the radiator, on the OUT line, before it goes tot he external coolers. I towed a few loads today, and the gauge never got more than a needle width above 100. Given it was darn cold and driving into the wind, it should still be over 150 with what I was doing.
I cant seem to find any kind of T adapter nor could I easily notice a place to put the sending unit in the transmission.
__________________
00 F-350 Lariat 7.3 CC LB 4x4 3.73 l/s, 305k, pop-up GN hitch, 6637, BD X-monitor, DP Tuner 40/80/140/drive-thru, exhaust brake
97 Freightliner FL70 8.3 6spd 21' stake, 181k
  #2 (permalink)
Old 02-09-2010, 07:13 PM
Izzy351's Avatar
Izzy351 Izzy351 is online now
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
There is a small plug in the driver's side of the trans, just above the pan. That's where the sensor screws in. It shouldn't require any adapters, and very little (if any) fluid will come out when you pull it. As long as it's cool.
Here's a pic:
It came from Diesel Manor's page:
http://www.dieselmanor.com/diy/PSD3-...73gauge-p1.htm
__________________
  #3 (permalink)
Old 02-09-2010, 07:16 PM
and this is the part where I feel sooo stupid.
__________________
  #4 (permalink)
Old 02-09-2010, 07:20 PM
Izzy351's Avatar
Don't worry about it -- this comes up from time to time. In the winter, mine barely moves. Maybe a hair over 100F. I'm running the very large 6.0L cooler as well, so that's not surprising when it's 30F out there. Do you have a larger cooler?
__________________
  #5 (permalink)
Old 02-09-2010, 07:22 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has much to be proud ofbig poppa has much to be proud ofbig poppa has much to be proud ofbig poppa has much to be proud ofbig poppa has much to be proud ofbig poppa has much to be proud ofbig poppa has much to be proud ofbig poppa has much to be proud ofbig poppa has much to be proud ofbig poppa has much to be proud of
Thats where I have mine. When its cold out it really takes time to come up on the gauge but thats about as accurate as you can get for temps from that port. IMO, unless requested, you should get all proper hardware to hook up your gauges when you buy, or I wouldn't.
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto w/ 142,000 Mods: GTP38R Turbo, S-B Intake w/Pete's Cover, MBRP Duals, DP Tuner Stock-60T-80E-120R-140E, J. Wood VB, 203* w/ billet housing, DS Coolant Filtration System, RDP FRx Fuel Crossover, RDP Boot Kit, HPX, RDP OCR Boost Fooler, 5100 Bilsteins, 2 Inch Level Shackles, 350 Rear Blocks-Thanks Keith,Cobra 29 LTD W/Dual Whips. PAA#26 Roadside Help Network 97 Expy XLT 4.6 113,000 stock and running strong.
  #6 (permalink)
Old 02-09-2010, 07:54 PM
every superduty that I have to do work on gets a 6637 filter, Shaeffers 9000 series oil and additional tranny coolers. I have been installing the square ones, about 8 or 10 inches square, I find them on excursions in the junk yards. Seems to really work nice and are easy to install, plenty of room. My 2000 F350 has one, in addition to the OEM coolers. Fully loaded with a high resistance load, I still run nice and cool. I use a BD monitor, sweet gauge, fantastic customer support and was straight forward to install. Uses the factory internal temp sensor, just tap into the wireharness.
__________________
  #7 (permalink)
Old 02-09-2010, 08:52 PM
Izzy351's Avatar
Yeah, if you have aux cooling, and it's 20F outside, you'll barely get it warm. I've actually been concerned about it being too cool in the winter.
__________________
Tags
03, 2004, 2005, 350, 73, f250, ford, gauge, hook, installing, powerstroke, sender, sensor, temp, trans, transmission, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
