Any difference between green and yellow antifreeze? - Ford Truck Enthusiasts Forums
Old 02-09-2010, 01:37 AM
Spaceman Spiff Spaceman Spiff is offline
Spaceman Spiff is starting off with a positive reputation.
Hi, just bought a 02 Screw with the 5.4l and would like to do a coolant flush. The manual says to use either green or yellow antifreeze? Is there a difference between the two?
Thanks
Old 02-09-2010, 12:42 PM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
My opinion, stick with the 50/50 mix of green and distilled water.
Old 02-09-2010, 01:58 PM
fordtech08's Avatar
fordtech08 fordtech08 is offline
fordtech08 is gaining momentum as a positive member of FTE.
yellow is the best fluid to use, however you can mix the two.
Old 02-09-2010, 05:38 PM
muddyford911's Avatar
muddyford911 muddyford911 is offline
muddyford911 is starting off with a positive reputation.
"yellow" or gold antifreeze is typically a long life antifreeze
Old 02-09-2010, 07:28 PM
Big Bad Big Bad is offline
Big Bad has a good reputation on FTE.Big Bad has a good reputation on FTE.
Yellow antifreeze is G-05, and is backwards compatible to 1999 in most Fords.
Do NOT mix the two, if you swap between them make sure you do a thorough flush and use distilled water in both cases.
Either is fine, but you can go 50,000 miles on the yellow.
Old 02-09-2010, 08:05 PM
fordtech08's Avatar
they can be mixed but you don't gain anything from the gold coolant if it is mixed with the green
Diesel antifreeze ihuntalot 1999 - 2003 7.3L Power Stroke Diesel 16 05-31-2015 09:52 AM
green antifreeze skytrash 6.0L Power Stroke Diesel 14 04-14-2014 09:25 PM
Yellow Liquid found on driveway hutchr 2009 - 2014 F150 7 12-27-2013 04:56 PM
Antifreeze 4wheeling79 1999 - 2003 7.3L Power Stroke Diesel 9 08-06-2013 12:57 PM
mixing coolant? dvfd12 1999 - 2003 7.3L Power Stroke Diesel 8 04-27-2009 09:49 PM
Tags
antifreeae, antifreeze, brands, coolant, difference, differences, f150, ford, g05, gold, green, mix, mixture, vehicles, yellow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
