e4od teca relay - Ford Truck Enthusiasts Forums
e4od teca relay
Old 02-08-2010, 03:51 PM
1bigjoe's Avatar
1bigjoe 1bigjoe is offline
1bigjoe is starting off with a positive reputation.
e4od teca relay
thank all of you who have been helping me get my truck equiped with the e4od , it went into limp mode, because the tachometer was not working.
so i changed the tach sensor----nothing
i changed the teca relay ---nothing
i chased the wires --no breaks
i pulled the cluster cleaned the connections-----nothing
changed the fipl-----nothing
changed the vass------nothing
switched the pcm------nothing
changed the trans control mod ---------nothing
what the f%^k
so i took off the teca relay again and jumped it from the power in to the pcm out ----- BINGO!!!!!!
the question now is why do they have the relay?
can i just leave it alone?
i just wounder how many guy's got trans rebuild because of that femal connection
Old 02-08-2010, 10:14 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
I think the relay handles about 20 amps of power. Simply routing that to the ignition switch will put too much load and cause a failure there. Same reason you have a starter relay instead of routing the battery cable to the starter switch in the column only scaled down. Electric fuel pumps typically draw 20-30 amps peak depending on the make and model and those also require a relay to protect the ignition switch.
Bottom line is you need to have that relay in there. As a temporary fix to get you home, you can just jump a wire across, but its not a long term solution.
I think I did hear of at least one possibly two trucks that hand the transmissions rebuilt over electrical problems like this.
Old 02-08-2010, 11:43 PM
steekers steekers is offline
steekers is starting off with a positive reputation.
TECA not PCM
I believe in previous posts from bigjoe, I stated that the TECA should be checked, not the PCM (which does not exist according to the Ford Truck Manual and the wiring diagram...still glad you got it fixed! Why you guys continue to call it a PCM amazes me.
Old 02-09-2010, 10:32 PM
hotrd3g hotrd3g is offline
hotrd3g is starting off with a positive reputation.
what is limp mode?
I may have the same problem after s builds and still not working right. Mine is a 97 powerstroke e40d.
Old 02-10-2010, 11:37 PM
Quote:
Sorry, I don't have manuals/wiring diagrams for your year...perhaps someone else will respond.
Old 02-11-2010, 12:53 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Without the relay, jumping from power in to power out will be sending power to the TECA all the time.
So your next problem will be dead batteries after the truck sets for a while.
If it is drawing 20 amps, overnight will be enough to kill them.
TECA or FIPL or wire problem with E4OD Transmission awolin 1987 - 1996 F150 & Larger F-Series Trucks 10 01-16-2017 04:26 PM
Do I need the TECA? awhtx Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 07-23-2016 05:19 PM
E4OD using stand alone diesel TECA 4x4slik 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-18-2016 08:55 AM
92 7.3 idi e4od O/D light flashing when rpms drop to zero idi73guy 1987 - 1996 F150 & Larger F-Series Trucks 11 12-03-2015 10:55 PM
no tach and trans is in limp mode...e4od bnuts677 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 01-19-2013 12:27 AM
Tags
73, diagrams, diesel, e40d, e4od, ford, idi, location, rebuild, relay, schematic, teca, transmission, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
