Brakes issue on my 53
My 53 f100 has been sitting a while because it has a starter issue. I finally got it started and was going to drive it to go fill up the tires. I noticed the brake pedal felt spongy. I checked the fluid and it was completely empty. It has been cold here in the mid west but I dont think that should have caused the fluid to drain out. I have not had any signs of any leaks or other issues when I was driving it daily. Any suggestions?
I've had this happen on other vehicles after setting. I'm not sure where it goes.
I say refill the master cylinder and see what happens. You can do a quickie cheat style bleed on it by leaving the lid to the master cylinder lid off and slowly working the brake pedal. Occasionaly working it several short strokes in the middle of the full stroke. Go slow on the pumping or it will spray brake juice all over the place. Alot of time you can work alot of air back out of the system this way without having to do a formal brake bleed.
In one sytem I tore apart (on an old motorcylce) the wheel cylinders were filled with a whitish paraffin type substance. I cleaned it all up, filled it with juice and had it working just fine.
Good luck
Bobby
Good luck
Bobby
We know that brake fluid is hygroscopic and absorbs moisture from the air and that the moisture must go into solution or it would freeze in the winter time. The “experts” say that static brake fluid can not evaporate but I wonder if a vehicle sits for a long time and the fluid is exposed to the air it becomes dilute to the point where it will evaporate at least the water content.
I think Julie is right, it must go the same place as the socks in the dryer do.
On all three of my F-100 in the summer months especially August our hottest month of the year usually I add dot 3 every month from a May to September. Not a lot maybe a long shot glass Texas style. Only twice and both times it was a rubber brake line that had brake fluid on it. Never did a brake bleed,just preload plastic cap the line and install it. AJ. Just thought of something I was installing a new master cylinder in my 54 that was the first F-100 I bought. I drove it from 1974 to 1985. Worked at an Airport and the Snap on tool guy wanted to sell me a brake bleeder. YepI bought it, and it’s still in the plastic case. Used it maybe twice, for ten years I paid Snapon $50.00 a week. But learned lots of handy issues. One was fill the resistor leave the cap off and lightly tap the brake pedal. You will see small bubbles in the fluid. Let it set over nite. Replace the cap in our case it’s a round cap. You should have brakes!AJ
ChevyExterminator
04-27-2021 03:26 PM
Luch
10-24-2013 09:33 AM
Colo79Ford
07-30-2005 10:00 PM
