Front Hub 4 Stud Torque Spec?
The new replacement hubs for my 04 F-250SD require 4 new (or reused) studs to be installed on the backside of the hub/wheel bearing.
Question: When installing the four studs, is the correct method to double-nut fasten the studs until seated (to no defined torque)?
I understand there is a controlled torque on the 4 nuts once the hub is installed into the knuckle .
Thanks very much for any help!
I just installed a new spicer axle shaft, put it all back together and the bearing is sticking pretty good. The bearing didn’t seem to have any issues when taken off.
wyckedcombo17
06-13-2011 11:51 PM
