Steering box splines?
Old 02-08-2010, 10:37 AM
Jbrown8988's Avatar
Jbrown8988
Jbrown8988 is offline
wondering if anyone has replaced there steering box and knows which one it is. NAPA says either 32 splines or 36 splines..... Ford dealer says there is only one and the 4x4 makes the difference. so of course they wouldn't tell me how many splines it had because they new i wasnt gonna buy it from them... so 2002 f-350 4x4 steering box 32 or 36 splines?
Old 02-08-2010, 12:25 PM
Texas Outlaw's Avatar
Texas Outlaw
Texas Outlaw is offline
Not a liberal...
Bumping because I want to know too.
Old 02-08-2010, 12:34 PM
Jbrown8988's Avatar
Jbrown8988
well if no one chimes in i will make sure i post which one it is when i tear her down tongiht.
Old 02-14-2010, 10:52 PM
HawaiianPSD's Avatar
HawaiianPSD
HawaiianPSD is offline
Did ya find out how many spline?
Old 02-14-2010, 11:03 PM
Waltdog's Avatar
Waltdog
Waltdog is offline
of American machinists
36 spline for my 2002 4X4
36 spline for my bosses 2003 4X4
Old 02-14-2010, 11:22 PM
HawaiianPSD
counted the splines on mine, with the key ways (flat spots) it's 36, without is 32. so which box do i go with???
Old 02-15-2010, 01:01 AM
WA.Ranger's Avatar
WA.Ranger
WA.Ranger is offline
Count the number of splines with the tip of a ballpoint pen, running it over the splines and counting the "peaks". The sector shaft has 4 big splines 90* from each other, count the splines in between two of them and multiply by 4. I know an early 99' I just helped to lift has a 32 spline, and my 01' has a 36.
PS- How have you been HawaiianPSD, truck still riding good?
Old 02-15-2010, 01:13 AM
HawaiianPSD
Thanks brother, looks like my 01 is 32 then.
I'm good man! Truck is good, gonna change the springs out one of these days and time for shocks too!
How you been?
Old 02-15-2010, 09:02 AM
BigJake34452's Avatar
BigJake34452
BigJake34452 is offline
i just went through this when converting mine to a 4x4, all mono beam (4x4 and the straight axle 2wd suspension in the 450's and up) use the 36 spline, but with the i beam fronts most came with 32 spline boxes and a few with 36.
Old 02-15-2010, 10:58 AM
frdf250's Avatar
frdf250
frdf250 is offline
yea i think the pre 2000 7.3's are the lesser of the two splines, i figured this out when i did my lift kit and had to replace the drop pitman arm.
Old 02-15-2010, 11:06 AM
BigJake34452
yeah i have the 32 spline box so i couldnt just put the right pitman arm on mine when we put the front end in, so a little modification and its good to go.
Old 02-15-2010, 12:32 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Been waiting to see pictures of that endeavor!
Stewart
Old 02-15-2010, 09:44 PM
snakedoc's Avatar
snakedoc
snakedoc is offline
I'm replacing mine and it is a 99 and it has 36 spines? could this be right should be getting the part to night so will see if it will work.
Old 02-15-2010, 09:53 PM
spdmpo's Avatar
spdmpo
spdmpo is offline
Only way to know for sure is to count them in a 90 degree area and multiply by 4 as said above. But when I researched the red head box I found the 4x4 trucks are the ones with 36 splines, the 2wd most likely have 32.
Old 02-15-2010, 10:01 PM
snakedoc's Avatar
snakedoc
snakedoc is offline
I just got the new one and it has 36 spines and it looks right, so for my 99 f250 4x4.
bit breaker
01-08-2022 07:34 AM
idiabuse
04-09-2017 10:53 PM
Sous
12-14-2015 03:12 PM
mofoco1
12-02-2015 09:33 PM
indyF-350psd
06-25-2012 05:24 PM
Quick Reply: Steering box splines?
