Popping Intake... any ideas?
There are many parts that costs us well over $1000 when it should cost us conciderably less, but due to the lack of demand prices stay way over inflated so the businesses can continue to do what they do. if they offered the parts for what they should cost they would go out of business is probably the logic behind that, but in reality MANY people want their parts, but can't afford to spend that on them so a price drop on many items such as rods, rockers, etc would get MANY more people buying those parts since they can now afford to do so. thats just my thoughts on stupid powerstroke costs in the aftermarket. sorry for the rant guys. LoL
So I know that the Diesel Innovations pushrods would be best...
my question is, how much power can stock pushrods hold? I'm looking for about 400hp eventually. My stock pushrods have 172k on them and are just now acting up, as far as I know.
Also, what do you need to change them out? Just basic tools and a torque wrench? Also what torque specs?
Just have to pull the valve covers and rocker arms right?
So just to be safe I should probably get the chromoly pushrods... I guess that wouldn't be the stupidest thing I've spend $200 on...
I really hope that it really is a bent pushrod making that popping sound... it's coming from the intake/6637 filter. Not all the time, just maybe 3 times a week.
Hmmm, I wonder about this! I had an issue prior to pulling mine into the shop to remove the engine for the swap. I went to fire it up, and it had a bad GPR, which I replaced, but I am also guessing the GPs themselves are bad. Anyways, I got a backfire out the intake with a flame. Another thing to check!
I have a question about this pushrod talk: Rideracelivemx7 commented that revving over 3K could bend pushrods. How likely is that to happen? Once in a while on here folks will give troubleshooting advice that includes revving at WOT, which will take it over 3K for sure. When towing I've revved over that to get her moving in 1st and 2nd gear and it doesn't seem to bother it a bit. Gassers rev to twice that high and I'm sure our pushrods are at least as beefy as a gasser's, so under what conditions can they bend over 3K or is there really not much to worry about?
Thanks for any input.
Did you see the pics i posted of the DI rods Brownie??? i posted 'em up several weeks ago. you will be quite impressed with them i'm sure. the torque spec for the rocker arms are 20 ft lbs... inspect your rocker arms real good. our rocker arms suck and like to crack.
here are the pics for you. you might look into upgrading your springs while your in there if you think your having a problem bending pushrods. if you pull the VC's and see no bent pushrods then you may have a valve not sealing too. i would personally take a look at everything first so you know whether or not you have a bent pushrod unless you don't mind getting the pushrods and springs also. they are pretty nice and definitely a good addition if you plan to use an aftermarket turbo later down the road.
Lariat86
03-24-2016 02:44 PM
djbeasties
04-01-2005 10:10 PM
JSKIER24
12-29-2001 11:10 PM
