brake shift interlock - Ford Truck Enthusiasts Forums
Old 02-08-2010, 06:13 AM
nhfire77 nhfire77 is offline
nhfire77 is starting off with a positive reputation.
I have a 2004 Explorer. 4.0 V6. I started it my aftermarket remote starter the other day. It wouldn't shift out of park, unless I used the bypass/override switch. Now every time I start it, with the key or the starter, I have to use the bypass/override switch on the bottom of the column to shift out of park.
The starter is a starter only no alarm. The starter has a kill switch. I have tried it in the off position, still the problem continues.
Also, the high brake stop tail light appears to have no power going to it when the brake it applied. The other brake lights are fine. I tested the bulbs.
I have checked the fuses for the Brake Shift Interlock (25 on the fuse block under the driver's side dash) and all the brake light fuses as well.
Is it the pedal switch that is bad? Any suggestions?
Old 02-08-2010, 12:04 PM
Steina Steina is offline
CO River Rat
Steina is gaining momentum as a positive member of FTE.Steina is gaining momentum as a positive member of FTE.
If the brake light switch was bad, none of your brake lights would work. With fuses and bulbs checking out OK, I'm wondering if the solenoid that unlocks the column shifter is gone..................?
Steve
Old 02-08-2010, 01:23 PM
Quote:
Steve
I am not aware of where the solenoid is located, I would like to find, pull it and test it.
Anyone know where it is?
Old 02-08-2010, 10:17 PM
CO River Rat
Removing the top and bottom covers of the steering column will hopefully expose the interlock system components. Also, Franklin (in the Electrical Systems/Wiring Forum) is a pretty good spark-chaser and may be able to help if you don't get any good info here.
Steve
Old 02-08-2010, 10:48 PM
Update:
I pulled a bunch of fuses to recheck that I did not miss a bad one. No bad fuses. Started the explorer to move it, and the problem is gone!
Was something frozen and cycling the power help? I pulled more than just the two I checked before, it was kind of a random check.
Old 02-09-2010, 02:46 PM
CO River Rat
The Owner's Guide references fuses in relation to interlock problems, so you may have cleaned up a tiny bit of corrosion when R & Ring the fuses. Hopefully the problem will stay gone...........
Steve
'01 Escape Stuck in Park; safety interlock gary7388 Escape & Escape Hybrid 35 12-22-2014 06:19 AM
No Brake Lights/Won't shift out of Park Bryan L. 1987 - 1996 F150 & Larger F-Series Trucks 4 10-05-2014 02:56 PM
No 4wd Shift interlock fuse blows 02 f250 Jo Diesel 1999 to 2016 Super Duty 4 01-24-2013 09:54 AM
What mechanisms/Fuses/ETC control the Brake Shift Interlock? ITDave 2004 - 2008 F150 2 07-11-2012 03:10 AM
Confirm things to check for shift/brake interlock issue TimGinCentralNJ 1997-2006 Expedition & Navigator 7 03-15-2008 05:20 PM
Tags
150, 2002, 2004, 2005, 2006, brake, brakeshift, bypass, explorer, f150, ford, interlock, lock, shift, switch, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
