1986 Ranger 2.3 gas-putting & stalling after replacing spark plugs - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 10-24-2012, 06:13 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
I would suggest before you throw $100+ at a re-manufactured EEC-IV, you check some basics. The computers are very rugged in your truck. They do not fail very often, and not often for no reason.
Remove the center wire from the distributor, and put a spark plug into the terminal. Ground the outer shell of the plug, and crank the engine over. You should get sparks. You should also get a spark when you turn the key from off to on to off. If you don't get a spark, you have an ignition problem that the EEC-IV module will not likely correct. You can run the ignition system with the timing jumper removed to take the module out of the picture. It will then depend solely on the thick film, the pickup and the coil. You could have a bad coil, and they are about $13.
If you look on this site or rangerstation you can find the instructions to pull the codes using an analog VOM, and a couple jumper wires. I will not search for you.
tom
1988 F150 4.9L Engine dies after warm UP 10 min. JMarsh 1987 - 1996 F150 & Larger F-Series Trucks 27 06-23-2016 12:52 AM
Stuck need help yeti1970 1961 - 1966 F-100 & Larger F-Series Trucks 6 05-26-2015 11:22 PM
'79 F-150 Ranger XLT, 351 5.8L DavidMc70 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-12-2013 12:32 AM
Ignition Key Switch 86 Ranger 2.3 EFI stalling when touched while idling. bozo4ford Electrical Systems/Wiring 3 10-10-2012 06:12 PM
No Spark to Plugs ddsvi 1987 - 1996 F150 & Larger F-Series Trucks 64 04-29-2011 11:17 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1986, 2wd, cap, changing, engine brite, ford, missing, pics, plugs, ranger, rotor, spark plugs, sparkplugs, stalling, truck, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
