2004 Explorer won't turn over..... - Ford Truck Enthusiasts Forums
Old 02-08-2010, 01:12 AM
scotty_fred scotty_fred is offline
scotty_fred is starting off with a positive reputation.
It drove fine when I parked it...I went out to leave next day and it won;t turn over....No clicking noise when I try to start it...The radio,heater and everything works full power...I just replaced the battery like a month ago...... Any ideas? Thanks
Old 02-08-2010, 10:42 AM
LTCPipkin LTCPipkin is offline
LTCPipkin is starting off with a positive reputation.
I had the same symptoms a few months back in my 2005. Turns out my transmission shift linkage cable is loose/broken. Haven't had time to deal with it here in the snow/cold. When it won't start in park, I simply slide the shifter from P to R to N (by feel NOT by the indicator needle on the dash). Once in Neutral, the safety over-rides will allow the engine to start. Recommend you engage the parking brake and remember to place a foot on the brake to allow the shifter to move as you locate Neutral. Good luck.
Michael
Old 02-08-2010, 12:02 PM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
Quote:
I don't own one of these trucks, so these thoughts are mostly theory. make sure if you have any theft or remote starter equipment that it is working properly. . if you have lights, power, etc. You probably have an issue with either your "starter control circuit" or your starter/solenoid is bad. devices that are part of your starter control circuit are , ignition switch, starter relay ,(I think in your power distribution box #12), neutral safety switch( if you have a standard itis a clutch positioning switch), depending on your ability you can take a multimeter and start checking these for power.
Old 02-08-2010, 12:52 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Does the "Security" or "Theft" indicator in the instrument cluster flash rapidly when attempting to start the engine? Does the blower motor shut off when the key is in the "Start" position?
-Rod
Old 02-09-2010, 04:31 PM
sadiejane sadiejane is offline
sadiejane is starting off with a positive reputation.
ck wire that goes to the starter solonoid for power they have been known to corrode causing bad connection
Old 02-10-2010, 06:16 PM
jrgoffin jrgoffin is offline
jrgoffin is starting off with a positive reputation.
Had a similar issue with my Aviator recently, but I was unfortunately told by some bozo at Autozone that my alternator was fine - it turned out that it was slowly croaking as I suspected, but he didn't know how to operate his test box well enough!
Anyway, all the accessories worked, but my battery was dropping below 10 volts (and it was a new battery as well). Without 10 volts, the starter relay will not even fire, so nothing will happen. Once I charged up the battery and replaced the alternator, all has been fine.
Before I figured out the alternator was actually going down-hill, I was thinking it was the ignition switch, or maybe the transmission range sensor, or maybe a defective battery, or maybe a loose wire...
Won't start Kevin Matthews 1987 - 1996 F150 & Larger F-Series Trucks 0 09-07-2015 12:44 PM
2004 F150 won't turn over..help nela808 Modular V8 (4.6L, 5.4L) 1 06-11-2015 07:28 AM
Trailer Brake Module Fault missionarymike 1999 to 2016 Super Duty 1 03-22-2014 08:16 PM
Actuating Rod or Ignition Sensor/Switch???? Bandit91 1987 - 1996 F150 & Larger F-Series Trucks 8 03-12-2012 11:36 AM
New-Battery/Starter/Starter Relay- Still won't Start!! alpine7572 1997 - 2003 F150 3 10-30-2005 10:40 AM
Tags
2004, 2007, engine, explorer, ford, over, ranger, relay, solenoid, start, starter, truck, turn, won, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
