FE clutch kits and pilot bushing- recommendations?
Old 02-07-2010, 10:43 PM
Bowtie_Schmowtie's Avatar
Bowtie_Schmowtie
Bowtie_Schmowtie is offline
For you FEs who have replaced your clutches, which kit/ manufacturer did you go with? I have about $150 to work with, and I will be using it for normal around town and highway use- not drag racing, pulling a 10000 pound trailer, or anyting like that.
And what kind of pilot bushing do you recommend- a solid bronze oil-lite bushing or a roller/ ball bearing? Many of the kits I have seen come with a roller bearing.
Old 02-07-2010, 11:02 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Can't beat ZOOM kits, great quality and price. And Roller Bearings are your best friend.
Josh
Old 02-09-2010, 04:01 PM
Bowtie_Schmowtie
OK, I've been looking and it appears that I am down to two choices:
Zoom MU2030-1 diaphragm style pressure plate, 1.163" input shaft
OR
Zoom MU7350-1 Long style pressure plate, 1.162" input shaft
I know that the diaphragm style is supposed to be smoother and improve driveability, but the Long style is what was originally in the truck. Is there a big difference in clamp load between these two styles, and does the .001" difference in input shaft diameter make a difference?
Oh, and where would you go to get a new clutch return spring and release fork?
I'll get a roller pilot bearing separately.
Old 02-09-2010, 06:32 PM
Bullitt390's Avatar
Bullitt390
For a daily driver with no heavy towing or drag racing the long style (or fingered) is the preferable one.
The diaphram is harder grabbing at the expense of your leg strength. Although ZOOM isn't considered that bad on the leg compared to McLeod or Hays. Centerforce is the dual diaphram that requires Arnold legs.
Not sure why they are listing slightly different input shaft diameters.
So, with that said, if the truck is a daily grinder with no forseeable future of towing or racing... long style
If engine upgrades, towing/ hauling or racing is in the future, might as well pay $10 more for the diaphram
Josh
Old 02-09-2010, 06:35 PM
Bullitt390's Avatar
Bullitt390
Oh...
NAPA should have clutch springs, not sure where to get a fork other than either the Junkyard or maybe NOVAK Transmissions.. Novak Jeep Conversions - Home
Josh
padrejerry
1983 - 2012 Ranger & B-Series
33
02-06-2016 09:13 PM
CelticOne
11-24-2015 07:14 AM
Swantastik
Escape & Escape Hybrid
11-10-2015 10:44 PM
Bowtie_Schmowtie
20
03-07-2010 04:54 PM
Greywolf
General Automotive Discussion
43
07-16-2009 05:49 PM
Quick Reply: FE clutch kits and pilot bushing- recommendations?
