All 6.4 Radiators are now covered for 5yr/100000 miles
#46
CRAZY 001:
Alas, I feel I have the bad luck--FIRST; although I hope NOT! I can vividly remember my 2003 6.0 Excursion with 35,000 miles as the turbo blades ground into the casing and each time I started it there was an excruciating sound, similar to the "DEATH RATTLE".
Then after trading, I took the green F - 350. A good ugly truck with a cover that took three guys to remove, as at the time I didn't realize how high the bed was on a F-350. And fighting with NHTSA or whatever it was called as FORD would not fix my TBC as it only gave minimal brakes upon hooking up, so I never knew if the brakes worked until the truck was going 15 mph. The NHTSA did pay for a new controller as FORD would not. And putting on shocks to solve the "death wobble" as my wife would not ride in the truck after a few episodes.
I almost cried when I was told my beautiful 2008 dark copper F-350 was diagnosed with a bad radiator. And then, all the oil on my floor and I found out the cab was coming off and the engine to be removed. BLAH! And then more oil. Oh, and inbetween a high pressure tranny line blew and another tow job to the garage.
Only way to end this is two fold. My 2001 Excursion was one awesome white vehicle with a V-10 but NOT 4 x 4 although white in color.
SO, LET ME SAY, this HOLIDAY season, "DEAR SANTA", please leave the problems on the "WHITE KNIGHT - 2011 F - 250 for at least three years. I am not against buying tires, and SANTA, even though my 2011 needs new wiper blades, I cannot call that a problem!
Rich
Rich
#47
#50
Now I get it. I must have deleted my cache. I did it again today as I have been experiencing some problems. This time I got a TOYOTA post. Wow, how could you not be signed in and not a supporter. I could not take all those advertisments.
I love it when I get an answer to my own dumb question.
Thx, Rich ...
Thx, Rich ...
#51
As a probable cap on this thread, let me extend a big thanks for all the info on the radiator/thermostat situation. I bought a '08 F350 in early December '10 with 41k mi. 2 weeks later it developed the famous leak. I'll never know if the dealer would have admitted to the coverage if I hadn't proven my awareness of it. I got it all from here so, thanks again!
#52
#53
I am about to have an anurizum....I took my '08 6.4 in last monday for coolant loss...Was called tuesday and told that my radiator is cracked and would not be covered and would be 1400.00.
I had no idea that this was a common problem but now I do...
Mine is a little different though...I lose a ton of coolant but NONE to ground...What is your thoughts on this?
thanks in advance....
BTW how in the heck can Ford expect us to pay for a bandaid...It would be different if you were paying for a fix but in my opinion it outta be on Ford till they remedy the problem...
#54
Did you read this whole thread? I'm going from memory which can be dangerous at my age but I think back a ways on this thread the real problem is identified as thermostats which fail and then cause the rad to fail. under those circumstances the rad is covered as are the stats. If it's not on this thread look at other threads on this subject, it's on here somewhere. May be a TSB. It's worth looking up and going back to the dealer with it, did they check the stats? Also, what do you mean the coolant is not on the ground, where is it?
#55
I actually went to a local rad shop and had them make me an all aluminum radiator greater cooling plus it'll last forever, I hope.
Ford wanted to charge me 1500 for mine. This is the 4th radiator mine has had. How can Ford not acknowledge a problem.
I believe if you aren't seeing coolant on the ground, it may be being lost in the egr system.
#56
I took the TSB about the thermastats with me today and was told the computer didnt show a code stating that they were bad (Didnt know that thermastats were computer monitered).
What I mean bye it isnt on the ground is exactly what it sounds like...It loses coolant but the coolant does not lay in a puddle under the truck instead it is disposed of thru the exhaust as occasoinally I have huge plumes of white smoke.
What I cannot wrap my hands around is that the powertrain warrenty is 5/100K but the radiator is not covered...but if you have a damaged radiator (which are damaged because a flaw in engineering on Fords part) you can do TREMENDOUS damage to the powertrain...You think that fixing this cooling issue would be ALOT cheaper than a set of Rods or whatever is damaged because of overheating.
#58
