change at home or pay for service? - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 02-21-2011, 03:56 PM
ottawaguy's Avatar
ottawaguy ottawaguy is offline
ottawaguy is gaining momentum as a positive member of FTE.
Well.....I apparently have missed the boat on that one. It is apparently not bad for the environment at all when fed into a properly designed combustion chamber.
If that is the case, which it is according to some sites I've looked at.
I've even been looking at plans to build my own....then I wouldn't have to cut down any more trees...hmmmm. Who'da thunk it?
The things I've learned here........
  #62
Old 02-22-2011, 04:49 PM
dkf's Avatar
dkf dkf is online now
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I take my used motor oil to a local farmer who uses it as fuel oil. I figure the motor oil more than likely burns cleaner and better than the preheated sludge that super tankers and cargo ships use for fuel.
  #63
Old 02-24-2011, 10:27 AM
onug's Avatar
onug onug is offline
onug has a good reputation on FTE.onug has a good reputation on FTE.onug has a good reputation on FTE.
I change my own oil. The local Ford Dealerships run specials, but it only includes 5qts of oil. So there is an instant up-sell for them. I've never been impressed with their speed either. If I have an option to sit in their waiting room for 60-90 minutes or do it myself, I'd rather be monkeying around in my garage while I wait for the oil to drain.
I tried to use the local oil-change shops in the past. They would consistently use the wrong oil and get their oily hands all over my hood and leather interior (and not clean it up).
Since I work three blocks away from PartGuyEd and enjoy doing the work (man time), I prefer to change my own oil.
  #64
Old 03-03-2011, 08:35 PM
someday someday is offline
someday is starting off with a positive reputation.
if u can do it yourself, then do it yourself...it only takes one time for them to mess it up and then the fun really begins
  #65
Old 03-04-2011, 02:59 AM
econoshorty econoshorty is offline
econoshorty is starting off with a positive reputation.
If they put the wrong oil in you engine and something breaks it will void the warranty and good luck getting a cheap-o-change shop to take responsibility. I had warranty work done on a Ford engine and that was the first thing they checked.
  #66
Old 03-04-2011, 10:35 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Quote:
How did they check and what was the nature of the failure? Ive always wondered if used oil analysis was used in such situations. You certainly cannot tell if the wrong SAE grade is in there by just looking and feeling. The viscosity is measured in the lab at the temperature of boiling water.
  #67
Old 03-04-2011, 12:49 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
They can (and do) ask for receipts to prove you at least purchased the oil. And believe me, if it was an oil induced failure, they will look closely for the type of oil purchased on that receipt too. I write when and what I did in the driveway in my owners manual.... in the back, they have space for that, then put the receipt for oil/filters/etc in the same packet and put it back in the passenger side door pocket.
  #68
Old 03-04-2011, 10:05 PM
Quote:
I dealt with the service manager and that's what he told me, how they check it I don't know I should have ask.
  #69
Old 03-04-2011, 10:28 PM
this was a double post and I can find no way to delete it...............duh-oh
  #70
Old 03-05-2011, 06:40 AM
ottawaguy's Avatar
Quote:
Always a good Idea to keep receipts. I do the same thing, but just keep a file in the house. I indicate the mileage and brand of oil used for the change(Mobil 1 of course). This is also valuable to show to a potential future owner should you ever decide to sell. I know when I'm looking at purchasing a vehicle, I always ask if they have maintenance records and/or receipts.
  #71
Old 03-05-2011, 07:31 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Quote:
Certainly good record keeping is a good practice but in the event of a warranty claim something methodical could go a long, long way to make the impression good and regular maintenance has been performed.
With computers creating a separate spread sheet type file along with a cross reference of invoice or receipt dates along with a separate file of receipt/invoice hard copies might be helpful as well.
  #72
Old 03-05-2011, 08:10 AM
ottawaguy's Avatar
I think having the hard copies is not just helpful, but rather necessary since that is the proof.
I keep all maintenance & parts receipts in chronological order which I think is sufficient. I put mileage on all receipts, not just the oil. I think that would be more than sufficient for a dealer as well. How would putting the same info on a spreadsheet indicate that you've done a better job of maintaining your vehicle?...it's the same info.
I suppose if you have the free time to put it onto a spreadsheet you could, but I don't see the point. What would you be cross referencing? I think you would need database software for that anyway.
  #73
Old 03-05-2011, 04:53 PM
JWA's Avatar
JWA JWA is offline
Well sorry if it came across I had a better idea, one that would serve any possible warranty claim better than your own system. I simply meant to suggest a second file MIGHT be helpful since receipts get lost or damaged etc etc. Back up files are just good record keeping regardless how its done.
On the other hand most MS Windows OS's tend to have simple spreadsheet programs onboard and its an easy thing to add your own data as repairs and maintenance occurs.
To each their own................... <!-- / message -->
  #74
Old 03-09-2011, 10:38 PM
even with all your receipts etc i think if your motor did blow the manufacturer could still tell you to talk a walk
  #75
Old 03-30-2011, 01:30 PM
21411 21411 is offline
21411 is starting off with a positive reputation.
change at home - see thread - oil filter how tight?
6.4 Powerstroke Report Scornwell 6.4L Power Stroke Diesel 10 01-04-2014 10:07 AM
Did my first oil and fuel filter change today Lt CHEG 6.4L Power Stroke Diesel 7 10-02-2011 06:48 PM
Service Cost? mohle 6.0L Power Stroke Diesel 15 04-12-2009 09:44 PM
Rear Main Seal AJD Explorer, Sport Trac, Mountaineer & Aviator 3 09-07-2005 03:32 PM
Anyone had a shiftkit installed in a C-6 weaver79 Clutch, Transmission, Differential, Axle & Transfer Case 3 07-15-2002 11:53 PM
Tags
beetle, bolts, changing, eod4, flmownerscom, fluid, ford, fords, late, model, oil, pan, plastic, removing, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
