Transfer case help
Transfer case help
Hi guys im new here but have been lurking around for a little while now. I've got two questions for you guys. My truck is a 1979 F150 4x4 http://i69.photobucket.com/albums/i5.../79F150032.jpg. I purchased the truck fairly recently and have been doing a little tinkering with it. After searching this site and countless other forums I thought I had figured out what transfer case I had. However, my shift pattern doesn't match up with a NP203 so I guess it might just be easier to post a pic and get some help. http://i69.photobucket.com/albums/i5.../79F150015.jpg
http://i69.photobucket.com/albums/i5.../79F150016.jpg
Also while trying to figure out the pattern and dealing with this darn B&M shifter I screwed up my linkage or something in the transmission. I removed the B&M and tried to move linkage by hand but nothing. Got under truck and tapped on linkage, nothing. Any help would greatly be apperciated.
sorry for the poor pics. I found the tag and cleaned it but due to the location I cannot read what it says. I thought it was a 203 based on the it not having a drain plug and being so large. However, the shift pattern seems like an H pattern with neutral in the middle:
4low 2low
n
4hi 2hi
4low 2low
n
4hi 2hi
that case is not a 203 the 203 is a fulltime 4 wheel drive case. and that shift pattern doesnt look like a 205 but in 79 you either got a 203 or 205. and in my experience i've never seen a case that has a 2low option.
hooligan24
04-05-2008 05:03 PM
pwillis44
05-30-2007 08:50 PM
