I need some help with a code and I/M Monitors! - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 02-07-2010, 01:28 PM
docbreece docbreece is offline
docbreece is starting off with a positive reputation.
Arrow I need some help with a code and I/M Monitors!
This is what I'm pulling out of my 2000 Expy with an Accutron OBDII reader.
Code: P1151 Manufacturer Fuel Air Metering
All my I/M monitors are good except Catalyst Monitor and Evap System Monitor, which say "Inc"
I got a Freeze frame, and this is what I read...
DTC causing: P1151
RPM: 1180
Load value: 71.3%
Coolant Temp: 188F
Short Term Fuel Trim1: 3.1%
Long Term Fuel Trim1: 0.0%
STFT2: 3.1%
LTFT2: 0.0%
STFT3: 61.6%
LTFT3: 57.0%
Veh. Speed: 42 mph
Fuel Sys1: CLSD1
Fuel Sys2: N/A
Any help? I want to see if it could be anything other than the MAF, as it's rather expensive....
Thank you!
Eric
Old 02-07-2010, 02:07 PM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Check to make sure your oil cap is on tight, the dipstick is in all the way, the PCV valve is seated all the way into it's grommet, and that the PCV hose is undamaged it's entire length.
Old 02-07-2010, 06:03 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Eric, I highly doubt its your MAF, as a problem with the MAF usually effects both banks.
Your P1151 is telling you that the PCM ran a test on your HO2S and the upstream HO2S on Bank 2 (i.e, driver's side) failed the test. It was stuck 'lean' at the end of the test and has not switched from lean to rich for a claibrated amount of time.
This code is keeping the Cat Monitor and the EVAP Monitor from running to completion.
Your HO2S may be dying, or the problem could be in wiring to the HO2S. (Or you may have a fuel issue (pressure, injector, etc). To save some $$, you could try swapping the left and right HO2S and if you then get a P1131, the HO2S is the culprit.
Old 02-07-2010, 10:38 PM
Good, good....
Quote:
Thank you. What exactly are you referring to when you say HO2S? I recently replaced the #4 coil pack, and the PCV valve position sensor switch(? I think that's what it was. It was a little black box above the engine on the driver's side, it had two vacuum lines running into it, and an electrical plug.)
Eric
Old 02-08-2010, 09:47 AM
Heated Oxygen Sensor
Old 02-08-2010, 01:35 PM
That sounds to me like you replaced the EGR solenoid. It is an electrical (hence, the electrical plug) solenoid controlled by the PCM. When the PCM activates the solenoid, vacuum is passed to the EGR valve to control the EGR valve.
Are you dealing with the 4.6 or 5.4 engine?
Old 02-08-2010, 02:00 PM
It's a 4.6. Egr, yes. Egr valve position sensor switch was its name-o.
Old 02-08-2010, 10:19 PM
Well, I checked my PCV valve, and I have LOADS of vacuum at the valve. The oil cap is on tight, and the dipstick is fully seated. Looks like it's probably the HO2S? How much trouble are we talking to check those? I've got my Haynes manual, and the process it describes is not one I can accomplish in my situation. Anyone know of another way? The manual describes using paperclips or something. Doesn't sound right. Also, I don't have a volt meter. What else can I check to rule out before I replace those O2 sensors?
Eric
Old 02-09-2010, 08:07 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
P1131 and P1151 DTCs are usually (but not always) caused by the upstream O2 sensor for the bank for which the code is posted. In the absense of in-depth troubleshooting, replace the upstream O2 sensor on the driver's side. Bosch, NGK, and Motorcraft are all good. Figure around $50-60 from a local parts store as a typical price.
You replaced the DPFE sensor. Hopefully, you got one from Motorcraft.
4.2L P2196_ No Fuel trim values from sensors downstream tlflood 3.8 & 4.2L V6 1 12-09-2015 05:25 AM
5.4L Triton Running Rich blaster4d Expedition & Navigator 3 12-26-2014 04:02 AM
05 Expedition P0430 Catalyst System Efficiency Below Threshold (Bank 2) WhyFord Expedition & Navigator 35 07-06-2014 03:30 PM
STFT/LTST question boj760 Modular V10 (6.8l) 11 12-01-2012 04:07 PM
Help Diagnose my OBD-II Scan Data Diamond-X Excursion - King of SUVs 13 09-15-2011 06:58 PM
Tags
2001, 30, dohc, evap, expedition, fault, ford, fuel, lincoln, monitor, navigator, ol, p1151, sys1, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
