78 F250 Dual tank fuel system - Ford Truck Enthusiasts Forums
Old 06-12-1999, 04:54 AM
Eric Ellis
Guest
Posts: n/a
Help!! I cant find a wiring diagram for my fuel sys ..I'm real tired of my fuel guage not working as its my daily driver..
Thanks to all ,Thunder...
Old 06-12-1999, 06:53 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Eric, have you thought to trace the wire by hand, they usually don't change the color code. You were not specific about why you needed help. The guages rarely go bad. Does either tank work?
John
Old 06-13-1999, 03:14 PM
Eric Ellis
Guest
Posts: n/a
I'm using the main tank now , tried to replace the fuse for the switching system,it blows even with an overrated fuse.I could trace them by hand ,but it would sure help to have a diagram to go by.
Thanks for responding ....
Old 06-13-1999, 03:58 PM
jowilker's Avatar
Man you have a direct short. You might as well start at the tanks and inspect the sending wire. There is a naked spot somewhere, and I'll bet on the chassis. As soon as you can find it either wrap it with tape or cut it and put in a coupler, then try a new proper size fuse. A fuse is a safty device, it lets you know that there is a problem. Adding a larger fuse is a hazzard and can cause more problems.
Your problem shouldn't be hard to find.
John
Old 06-14-1999, 09:16 AM
abowie abowie is offline
abowie is starting off with a positive reputation.
Old 04-01-2005, 11:56 PM
ressery ressery is offline
ressery is starting off with a positive reputation.
My guess would be the tank selector solenoid. It's located in the frame rail just ahead of the front tank. Unplug it, put a new fuse in and try the switch. If the fuse holds, it's the solenoid.
Only about 5' of wire to inspect from there to the engine bay. Most of it's easy to get at.
Roger
Fuel question dobenator 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-03-2015 01:58 PM
Diesel/Fuel smell in cab Stu206 1999 to 2016 Super Duty 6 01-10-2014 05:00 PM
Fuel Filter TennesseeRV 1999 - 2003 7.3L Power Stroke Diesel 41 01-04-2013 08:01 PM
Blue fuel in my fuel bowl dooleyservices 1994.5 - 1997 7.3L Power Stroke Diesel 8 12-28-2011 03:37 PM
fuel leak ? jimwilsonmasonry 1994.5 - 1997 7.3L Power Stroke Diesel 6 07-14-2008 04:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
