I used a piece of 4" exhaust pipe with a 45 deg bend in it. I believe it was 12" long on each end. I just cut the one end to fit. See my photo gallery. It came from NAPA. The only thing is the filter sits crooked. But I don't mind.
I love the way that looks! Mind telling me how you bent it? I have access to a good mig and grinders and I'm not to shabby at either one... I'd love to see if I can get a bit more whistle outta my truck if I used a metal intake pipe.
I'm assuming you have an early 99, here's a kit put together by Clay that incorperates that bend in the pipe, nice kit, no guessing . Riffraff Diesel: RDP 6637 Filter Kit
clay ships the early 99 kit with a late model final boot (99.5-03) i was the first and it fit good off the ccv eliminator pipe. he said it was cheaper than doing the 45 degree pipe w powdercoat. but im sure he can get made whatever you could want.that reminds me i need to tell him it fit ok.
I really like the looks of this too. But one question comes to mind. When the accordion is replaced with a solid tube, what's left to allow the motor to rock and the filter to stay put?
I'm thinking that's a bigger turbo. But just a guess. I think the bigger turbos have a 4" intake already and thats why they come with a different boot to go from the intake to the turbo.
Delux06 made that from different degree 4" pipe (exhaust pieces). He has a post on this forum somewhere showing how he did the pipe.
with a full tube from turbo to filter, wouldnt this setup be better than most aftermarket kits, -the cold air bowhich could easily be made with cnc plasma table) It looks like most aftermarket intakes only have tubes to the factory reducer.
