2006 Hard steering - Page 2 - Ford Truck Enthusiasts Forums
Old 11-03-2014, 09:54 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
2006 Hard steering
Old 05-18-2014, 10:56 AM
Tsibley Tsibley is offline
Tsibley is starting off with a positive reputation.
Don't get discouraged if this doesn't work right away.
My steering got so tight it became a 2 hander. I had heard that the power steering fluid could get contaminated. So while having an oil change I had them flush it out and put in a high quality synthetic... Nothing! I then found this forum, went out to the truck and saturated the steering shaft joints with WD while turning the wheel left to right... Nothing! Saturated them again and let it sit overnight... Nothing! I then went to the quarter car wash and power washed the joints, saturated them with PB Blaster to penetrate and finally with WD to lubricate... My steering is now brand new!
Old 05-18-2014, 03:46 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
I hope you made sure they filled it with Mercon V trans fluid.
Quote:
...saturated them with PB Blaster to penetrate and finally with WD to lubricate...
There are much better (my opinion) lubricants you can use instead of WD40.
Stewart
Old 03-22-2015, 03:18 PM
Shatrab Shatrab is offline
Shatrab is starting off with a positive reputation.
Steering tightness
This is a great thread as it has saved me a lot of money by not replacing the power steering (as many will diagnose this as), WD -40 did great job initially, a few months ago. Recently it got tight again, so I loosened the top bolt and slid the collar down so I could feel the resistance in the motion of the top u-joint in this steering linkage (the bottom u-joint has a boot and is protected so I didn't bother that one). It showed resistance in one of the two directions of travel. There are 4 tiny rubber sleeves that protect the bearing yolks from the elements, and after pushing a very small screwdriver into the edge of each rubber sleeve and pulling it up, a temporary gap is created that will allow better lubrication. I used WD-40 initially, then dripped oil into the gap (while working the direction back and forth), wiped area off as well as the rusty residue that worked out of the cups, and used a medical needle to inject grease into this area. After a while (about 20 minutes) of working the cups to loosen movement, both direction paths were very loose. I believe I will not have to do this again now that there is grease protecting the u-joint cups.
Thanks to those that correctly diagnosed this issue in this forum!
Old 10-18-2015, 09:30 AM
Forever Free Forever Free is offline
Forever Free is starting off with a positive reputation.
My 2004 f150 has hard steering. I bought a new shaft but the new one doesn't have a slip joint. Is this going to be a problem.
Power steering problem - hard to the right Happyreefer Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 22 09-19-2016 08:49 PM
Power Steering Fluid VS Transmission Fluid t24021994 1987 - 1996 F150 & Larger F-Series Trucks 9 05-24-2015 01:50 AM
Heavy steering thinksnow 6.0L Power Stroke Diesel 10 05-06-2015 07:20 PM
steering abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 33 07-10-2014 03:15 AM
Power Steering Issues 5.4L to Freedom 1999 to 2016 Super Duty 18 02-13-2011 04:55 PM
Tags
150, 2003, 2004, 2006, f150, feels, ford, hard, lube, power, problem, steering, sticking, stiff, ujoint
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
