First drive! Edelbrock F-150 supercharged - Ford Truck Enthusiasts Forums
Old 02-06-2010, 12:49 PM
Coupleofords Coupleofords is offline
Coupleofords is starting off with a positive reputation.
Holy smoley!
Spent some time driving Edelbrock e-force supercharged 5.4 prototype.
Amazing driveability, instant response, quiet, smooth, with just enough added grunt to move a heavy load when needed. Keep foot out of it (hard to do) and expect stock mpg. Absolutely factory looking install.
I want one. Bad.
Brian<!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->
Old 02-06-2010, 12:59 PM
stephen.osborne1's Avatar
stephen.osborne1 stephen.osborne1 is offline
stephen.osborne1 is gaining momentum as a positive member of FTE.stephen.osborne1 is gaining momentum as a positive member of FTE.
Any pics, video, stats? I've been strongly considering forced induction. Is this just a supercharger or an entire truck modified by Vic?
Old 02-06-2010, 07:22 PM
I had no camera, or permission to take and post pictures. But, their 2010 catalog is out, or check their website. The truck is box-stock, red of course.
Old 02-10-2010, 11:24 AM
I'll be driving it again for a couple days next week. Other than price, I'll report more specifics. Any questions I should ask? Brian
Old 02-13-2010, 06:59 PM
09_XLT 09_XLT is offline
09_XLT is starting off with a positive reputation.
Quote:
Yeah, what octane gas is required with the supercharger?
What is the RWHP and RWTQ with the unit?
Do they need more test mule trucks? (mine)
Old 11-09-2010, 08:03 AM
deltaboost deltaboost is offline
deltaboost is starting off with a positive reputation.
Has anyone supercharged a 5.4L with the 6 spd auto? Just curious what the trans can/can't handle..
Old 11-09-2010, 09:55 PM
Jus2shy Jus2shy is offline
Jus2shy has a great reputation on FTE.Jus2shy has a great reputation on FTE.Jus2shy has a great reputation on FTE.Jus2shy has a great reputation on FTE.Jus2shy has a great reputation on FTE.
I am watching this and will probably save up money over the next year to purchase a kit. What I would like to know are:
1-Can the 5.4 still use E85 with the S/C kit?
1a-If it can, did they re-map the fuel curve for E85?
3- Did they alter the transmission shifting parameters to take advantage of more lower end torque? Maybe hold a gear a little more before deciding to downshift?
4-can you order spare water pumps for the liquid to air intercooler?
5-why do you need the oil filter relocation kit for a 4x4?
6-does it still use the factor stock air box (or similar)? I want to avoid any cotton gauze filter setup as much as possible
Other than that, I'm excited to hear your thoughts on how awesome the kit is. It's far cheaper than attempting to swap a 3.5 ecoboost (I mean you have the engine, harnesses, and electric power steering to swap!)
Old 09-06-2012, 09:13 PM
Jayybird Jayybird is offline
Jayybird is starting off with a positive reputation.
Hi,
What brand and where can the superchareger kit be purchased? I have a 2010 Ford F150 with 5.4 flex fuel and very interested in a supercharger or turbo kit.
My truck has a 6" lift with 35" tires, crew cab Tuscany Package. Just got a company work truck and making this truck my toy.
Info much appreciated.
Old 09-07-2012, 01:18 PM
Wiggums's Avatar
Wiggums Wiggums is offline
Wiggums is gaining momentum as a positive member of FTE.
For the California residents, I see it's CARB-approved for 2004 to 2010 models! Awesome, too bad mine's a 2012
Old 09-07-2012, 05:26 PM
Quote:
Originally Posted by Jayybird View Post
Hi,
My guess would be that it is an Edelbrock supercharger, which should be available on their website.
Old 09-07-2012, 07:29 PM
msgtord's Avatar
msgtord msgtord is offline
msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.
Old 01-03-2016, 02:36 AM
F2504life F2504life is offline
F2504life is starting off with a positive reputation.
I had the same problem. Tried chasing down a vibration for months. It ended up being that I needed to replace the ujoint straps ($7 from oriely's). The ujoint was loose enough to allow the drive shaft to move 1/8th inch I either direction. Anyway, I replaced the straps and no more vibration.
Old 01-03-2016, 07:34 AM
paredneck33's Avatar
paredneck33 paredneck33 is offline
paredneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to behold
Quote:
If your truck is a 2012, then the supercharger wouldn't work for you anyways. It's for a 5.4 V8. The last year the 5.4 was offered in an F-series truck was 2010. But was continued in the E-series vans, Expeditions, and Navigators until 2014.
Old 01-03-2016, 11:28 AM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
This is an old thread which appears to have been revived by mistake.
Wiggums hasn't posted since 10/2014.
Old 01-03-2016, 11:30 AM
meborder's Avatar
Quote:
F2504life:
Let me know what thread you meant to post to and ill gladly move it to the proper spot.
Welcome aboard!
New Jersey Member Roll Call sddesigns New Jersey Chapter 92 10-07-2016 09:15 AM
2004 explorer windows quit working - jabro Explorer, Sport Trac, Mountaineer & Aviator 9 01-19-2016 04:55 AM
April Truck of the Month Voting Arlene Delaware Chapter 13 03-25-2010 01:07 AM
E100 on F150 4X4 Frame Four_X_Ford 1968-2013 Full Size Vans 4 01-05-2010 04:38 PM
any easy way Eddiestruck Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 05-05-2009 05:18 AM
Tags
150, 2009, 2010, 4x4, car, edelbrock, edlebrock, f150, ford, mpg, supercharged, supercharger, superchargers, superchrged, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
