6R80 Transmission Drain Plug
I don't do Trans flushes. I change out the filter, drain and refill...
Then drain/refill within 3000 miles and again 3000 miles later. Change the filter on the last drain/refI'll. So having a drain plug works. You don't need to change filter every 3000 miles. But the fluid only gets mixed 7 quarts at a time until you change out all the fluid.
The Jeep filter is attached to the valve body, where the Ford just kind of sits there. The PML pan does have filter supports however I'm a little concerned about how well they actually support the filter against the valve body.
Until recently the filters were designed for the life of the transmission. If you read the maintenance schedules you won't find a recommended change interval for the filter. There isn't one. That started changing about 2008 when the filters were improved and DO have a change interval.
I've seen a filter cut open that had 369,000 miles on it. The only reason the trans was touched was that the ambulance it had been in was totalled in a wreck. Engineering at Ford had been monitoring that company's fleet, so we got the trans back after the wreck. The filter was still fine and could have lasted many more miles.
Mark,
as you said until recently...can you give me a rough idea of what the actual life of the filter is then? I ask this since I placed a new filter on my 4R70 at 100k and at that time put a B&M deep sump pan on as well for ease of the drain, fill and the extra 2 qts of tranny fluid (I worked on fluid power systems and know that a measure of your heat can be wicked off with extra fluid reserve as well as a nice, finned aluminum pan :P )
Thanks!
D
Thanks!
D
