Fuel Damper Failure?
Old 02-06-2010, 11:23 AM
jd_boggs's Avatar
jd_boggs
jd_boggs is offline
Has anyone come across fuel damper failure?
My truck: 2002, 2.3L, 5 speed, 75,000 miles. Engine has power loss and misses badly when the engine is under stress either up hill or after shifting to 3rd or 4th (low engine rpm). Otherwise engine runs well at 50+ MPH but when I have pass another car it starts missing and thus looses power.
1. Have tested the fuel pump (out of the tank) at 79 psi should be 56-72 psi.
2. Removed fuel tank and cleaned tank and pump (was not dirty)
3. Replaced the fuel filter just because.
4. Replaced air filter (was very dirty)
5. Cleaned the MAF with MAF cleaner.
6. Measured ALL voltages at MAF all well within limits including all RPM ranges.
7. Ran 2 fuel tanks with injector cleaner additive at high speed.
Only thing left is the fuel damper any ideas?
Thanks.
Old 02-06-2010, 11:52 AM
powersmoked's Avatar
powersmoked
powersmoked is offline
You should do a pressure test with koeo and keoer. I think the regulator is in the tank. I have not not seen anyone that needed a new damper. pull the vacuum line off of it and check it out. check for codes even if the cel is off. you have the Duratec right? Have you done any maintenance on it?
Penton97F150
1997 - 2003 F150
06-26-2016 10:49 PM
iridius
1997-2006 Expedition & Navigator
05-18-2016 01:31 PM
gbrooding
09-07-2011 05:46 PM
Danimal1481
02-21-2010 02:44 PM
hossbuilder
20
10-12-2009 06:00 PM
Quick Reply: Fuel Damper Failure?
