ABS module - Ford Truck Enthusiasts Forums
ABS module
Old 02-06-2010, 11:36 AM
mjones802 mjones802 is offline
mjones802 is starting off with a positive reputation.
ABS module
<hr style="color: rgb(209, 209, 225); background-color: rgb(209, 209, 225);" size="1"> <!-- / icon and title --> <!-- message --> <!-- BEGIN TEMPLATE: ad_showthread_firstpost_start --> <!-- END TEMPLATE: ad_showthread_firstpost_start --> Hello, new to this forum and looking for opinions. I have 1 2002 F150with 39000 miles that I am having trouble with the ABS system. Have hooked up 3 scanners including one at <nobr style="font-weight: normal; font-size: 100%; color: darkgreen;" id="itxt_nobr_0_0">Ford</nobr> dealer and the codes C1229 and C1230 keep showing up . Three different rear speed sensors have been installed including one at Ford dealer and the light still comes back on. Dealer run a Pinpoint diagnostic test and said it pointed to the ABS module. The two codes reference rear speed sensor circuit failure and coherency fault.
Before I spend $500.00 + for an ABS module I would like to get some input from you guys.
Thanks
Old 02-06-2010, 11:43 AM
torkum's Avatar
torkum torkum is offline
torkum is gaining momentum as a positive member of FTE.
Check with the guys ABSFIXER.COM / ABS EBCM Repair
Old 02-06-2010, 11:38 PM
jennkent5454 jennkent5454 is offline
jennkent5454 is starting off with a positive reputation.
just unplug the damn thing, I have had mine unplugged for over a year now. your brakes will still work fine, you just wont have ABS. when you send your module to fixed it will not be on the truck anyway. look on ebay there are some guys on there that rebuild them as well, I think ive seen them for about $75-$100.
Rear Main Seal is Leaking OutlawNomad New Jersey Chapter 7 04-07-2010 09:07 AM
2.9, (1994 Ranger 3.0), 4.0 HP/Torque reliability comparison. jackofalltrades Ranger & B-Series 3 01-29-2010 12:44 PM
One Weak 460 thekingofcows Performance & General Engine Building 9 01-04-2010 09:49 PM
Torque spec Dana 80 GTOBRIAN 1999 to 2016 Super Duty 0 12-08-2009 08:21 PM
10.25 rear oil change ghunt Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 10-27-2009 05:27 PM
Tags
1997, 2001, 2003, 4x4, 97, abs, c1230, circuits, code, f150, ford, module, rear, testing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
