4 wheel drive question (manually turning hubs)
#32
#33
The ESOF works when I turned the dash dial to 4x4 high with the hubs in Auto because the EX got out of being stuck in the snow in 2 wheel drive.
Now After I turned the hubs to lock the EX REALLY had traction in the snow.
I have used 4 wheel drive more in the last 3 weeks sine I got it in 2004.
#34
#35
So my question is" Why is there even a LOCK position on the hubs?" It does have additional traction with the dash switch on in the HIGH position ,but it seemed better with the addition of the hubs in the LOCK position.
#36
Try this test. Turn both hubs to auto and leave the switch in 2wd. Reach behind the wheel/tire and try turning the axle shafts on both sides by hand (turn the u-joint). They will be free to turn when the hubs are not locked in (as they should be when in auto and 2wd). Then start the vehicle up and turn the switch on the dash to 4wd. You should drive forward a bit to ensure engagement. Turn the vehicle off and again try to manually turn the axle shafts. You should not be able to turn them now. If you still can, the ESOF vacuum system has failed. This is why they have the lock position. Note that the system has many other failure modes than just this one. One hub can lock and the other not (this is bad). They can be stuck locked when the dial is in auto (this is common). And the dial can be froze up (as mentioned before). Try this test and let us know what you find.
#38
#39
andy
The right way to fix is explained in detail on Guzzel's page (see earlier post in this thread).
If you need to manually lock auto hubs then the vacuum system is not working.
IF you have trouble turning the dial, WD40 may help as explained above.
There are a lot of possible failure modes for the ESOF system; some you can work around by locking the hubs manually. If that works, there's little to be gained from aftermarket hubs, except that you can expect new hubs to not fail further, at least for a number of years.
#41
