dash code e 08 6 - Ford Truck Enthusiasts Forums
dash code e 08 6
Old 02-06-2010, 01:16 AM
koldhearted1 koldhearted1 is offline
koldhearted1 is starting off with a positive reputation.
dash code e 08 6
dash code is showing up on my odometer anyone have any ideas what i need to do to fix it? speedo needle sweeps at first turn of key then nothing after that bout all i can tell you.
Old 04-23-2010, 03:27 PM
Cowboy350 Cowboy350 is offline
Cowboy350 is starting off with a positive reputation.
Did you ever figure out what the problem was. I have the same thing going on. Thanks.
Old 04-23-2010, 03:29 PM
nope not a clue other than the speed sensor in the trans might be bad
Old 04-23-2010, 05:29 PM
darthice's Avatar
darthice darthice is offline
darthice is starting off with a positive reputation.
check the connector under the dash on the passenger side to see if the wire is grounded out it is going into programming mode
Old 04-23-2010, 05:49 PM
darthice thanks for the response ill check that out glad someone else had the problem to bring the thread back up the board. if it is in programming mode how do you get it out?
Wrench Light with No Codes strokenboost Modular V8 (4.6L, 5.4L) 2 08-22-2016 10:49 AM
Which tool for OBD 1 scanning? ChRoNo16 1987 - 1996 F150 & Larger F-Series Trucks 4 05-30-2016 09:17 PM
Dash codes wolffee 6.0L Power Stroke Diesel 4 12-13-2013 07:31 AM
Dash paint color? F-250 Super Duty 1999 - 2003 7.3L Power Stroke Diesel 29 07-25-2013 12:37 PM
Read Codes in Dash Display commandersander 1999 to 2016 Super Duty 8 04-09-2009 09:21 AM
Tags
08, 086, 1994, 1996, 6, code, codes, dash, dashboard, e, e086, f150, ford, speedometer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
