I just got a hold of superduty HPOP for my 7.3, I heard there is someone out there that can mod. it to up around 18* ( or the same as an Adrenalin pump) instead of the 17* stock. To answer anyones question of WHY, because some stage II's will be soon.
I believe that you are thinking about terminator engineering. Cody and Travis are the only two that I know of off of the top of my head on here with one, but they do pretty darn good keeping the psi up. If either of them don't post up in here you might want to send them a pm and get some more info.
Richard is right. Contact Joey at Terminator Engineering about his modified 17 deg pump.
The down side is, I don't know how much of a credit you'll get for trading in your new 17 deg pump. Maybe he'll take your old HPOP in as a core and you can sell the super duty HPOP for a couple of dollars.
I think you might have to send in your 15* HPOP along with the 17* SD HPOP and they use both to build yours. They swap the 17* internals into your 15* pump housing or something like that...
The 17 is a bolt in swap for 96 and newer engines from what I've read. 94 and 95 need the guts swapped in to the 15 housing. I'm assuming you're upgrading the 96 in your sig, that would allow you to send the 17 in for Joey's upgrade mods while your rig still runs on the 15.
Ok, I was thinking about my '95. Wasn't sure if the 96-97 were the same.
Yes, just send the 17* to Joey. He'll mod it for ya and send it back. No need to swap cases. Email him and ask him all the questions you have and you'll be good to go. But don't suffer the same fate I did, insure the package and get tracking if you use the post office. The conviniently lost 4 pumps I sent Joey in Jan.
