Tail light backup light stays on in all gears. - Ford Truck Enthusiasts Forums
Old 02-05-2010, 07:25 PM
weiress's Avatar
weiress weiress is offline
weiress is starting off with a positive reputation.
The white square on my tail lights seem to stay on all the time, when the headlights are on.
This started some time after replacing the headlight switch. I'm not sure if that was the catalyst or not. Is there any other explanation?
I dont think its possible i have the two lights mixed up inside.
Old 02-05-2010, 07:35 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Are the tail lights on as well or just the reverse lights?
Old 02-05-2010, 07:39 PM
weiress's Avatar
The tail lights are on too. Both top and bottom bulbs are lit.
Old 02-05-2010, 10:47 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
What year is this? Is this a standard or automatic?
Old 02-06-2010, 02:42 PM
weiress's Avatar
74 F100 explorer - automatic.
Old 02-06-2010, 11:11 PM
TexasTrash's Avatar
TexasTrash TexasTrash is offline
TexasTrash is starting off with a positive reputation.
Were the lights working before, and did you take it to a shop to have the work done.
My reverse lights aren't hooked up, i took it to a shop to have the headlight switch changed once and when i got it back the reverse lights would come on when i started the truck. They hooked up a wire to see if they worked and never took it off.
Old 02-07-2010, 12:43 PM
weiress's Avatar
I like your idea of just disconnecting the reverse light. It's better than my idea of covering it with red tape. We could all use less red tape in this world.
Im not sure when it occurred, but potentially after i replaced the headlight switch (which i replaced for a different reason.
Old 02-09-2010, 04:53 AM
brooklyn brooklyn is offline
brooklyn is starting off with a positive reputation.
check local regs, i failed inspection because my backup lights & horn were disconnected. i made the mistake of thinking the huge sign saying "brake tags" meant all i had to have working were my brakes.
i'm like 80% sure that on my 78 f-150 it's a solid green wire, but could be wrong. borrow a cable tracker & you can have this sorted in like 10 minutes.
Old 02-09-2010, 12:25 PM
jb10 jb10 is offline
jb10 is starting off with a positive reputation.
i have a very similar problem. the right side reverse light is always on. even when the parking and headlights are off. i haven't even begun to look at it yet. any ideas?
Old 02-09-2010, 12:35 PM
The back-up light switch itself is most likely the problem.
Old 03-21-2010, 11:30 AM
fdaniels's Avatar
fdaniels fdaniels is offline
fdaniels is starting off with a positive reputation.
Where is the backup light switch on a 1979 F100 located? My backup lights don't work and I'm thinking the switch is the problem.
Old 03-21-2010, 07:03 PM
awsmev's Avatar
awsmev awsmev is offline
awsmev is starting off with a positive reputation.
Quote:
Auto trans is on side of trans where linkage is attached to trans. it is the same as the nuetral safety switch
Old 03-21-2010, 07:25 PM
fdaniels's Avatar
thank you for the reply
Old 03-30-2010, 07:10 PM
weiress's Avatar
I got a Backup Light Switch for my 74 F100 but cant figure out where it goes. Would mine also be under the car and next to the tranny?
Is it anywhere near the steering column? i cant find it.
Old 03-30-2010, 07:35 PM
awsmev's Avatar
Auto or Manual?
Headlight on no tail lights gdkaufman 1987 - 1996 F150 & Larger F-Series Trucks 4 11-18-2016 05:15 PM
running lights tail lights and dash lights 6.9idiatsturbo 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 08-15-2016 06:54 PM
Front running lights question -easy- steuspeed Ranchero & 1961 - 1967 Econoline 3 07-29-2016 05:12 PM
head/tail-light problem 00 f150 One79one71 Electrical Systems/Wiring 9 12-18-2014 08:57 PM
No tail lights or rear parking lights johnson2007 1973 - 1979 F-100 & Larger F-Series Trucks 17 10-03-2011 09:24 AM
Tags
74, 78, back, backup, f100, ford, light, lights, reverse, stay, stays, switch, tail, taillights, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
