coolent gone missing
I have noticed since I got my 77 400 4x4 that I always have water in the exhaust even after warm up. Just the other day I noticed that during idle my temperature was heating up took a look under the rad. cap. Uh-Oh. looks like coolant is missing.
Question this sounds like head gasket is corrupt, what is the likelihood of this and should I Look elsewhere first for cheap fix?
And when I pull the head gasket (which I haven't ever done on a engine) is there anything I need to know? what else could be broken that I need to be aware of?
the water in the exhaust also explains my new exhaust leak I can hear... sigh.
yes it for sure is I also have "white stuff" on the oil fill cap so that sealed it for me. I do have another post here head gasket replacement - Ford Truck Enthusiasts Forums
so this thread is mostly answered.
but thanks for the tips on what all I need to replace can you check out my other post for anything else I am missing?
this would be the first time I have taken a engine apart this far, so any advice on common things that are messed up would be cool!
All bolts stretch, it is that stretch that provides the clamping force which holds two objects together. This is a torque value.
Now some head bolts can be used over and over again, and some do not. Most modern engines use a one time TTY or torque to yield bolt that should not be used after initial torque.
Most early engines have standard hardened head bolts that can be used again, but you will want to clean the bolts and run a tap into the holes in the block.
False torque values might be encountered if you dont start with clean threads. I also like to soak the bolts in oil after they have been cleaned.
Typical heat cycles of the engine will not change the hardness of the bolts, and these can be used time and time again.
Problems usually begin with improper installation, and most of the mistakes are from dirty threads.
Tim Hodgson
68
04-29-2018 11:47 AM
michbol
11-14-2011 01:25 PM
