Starter motor bolts? - Ford Truck Enthusiasts Forums
Old 02-05-2010, 04:58 PM
brooklyn brooklyn is offline
brooklyn is starting off with a positive reputation.
Anyone have length/width of a 351m starter bolt? Are there only 2?
I've got a piece of what looks like threaded rod or a snapped bolt sticking out of one, nothing visible in the other. Starter won't engage & it's not the battery or solenoid.
...and I gotta pick up the beer & barbecue for the game on Sunday.
Old 02-05-2010, 08:41 PM
Danny Stroup's Avatar
Danny Stroup Danny Stroup is offline
Danny Stroup is starting off with a positive reputation.
There are 2 bolts holding the starter to the bell housing...one on top; the other on bottom. The head of one bolt (I think bottom) points towards the rear of the truck and screws into the bell housing. The head of the other bolt (top?) points toward the front. It's screwed in from the opposite side, passes through the bell housing and screws into the threaded hole on the starter mounting.
I discovered this after thinking that one bolt was wrung off and I took apart the starter while still attached by the top bolt. After breaking off the mount housing with a hammer, the top bolt fell onto my chest...haha
I felt pretty dumb afterwards.
Old 02-05-2010, 08:47 PM
oh, wow, thanks! the autozone guide just said "remove the two bolts" ...i'm missing six other bolts right next to the starter so when i didn't see the heads i just assumed something else had gone wrong.
Old 02-05-2010, 08:57 PM
moose4x4's Avatar
moose4x4 moose4x4 is offline
moose4x4 is starting off with a positive reputation.
They should be 3/8 standard thread about 1 1/2 inches long.
starter question Jeff heine 1999 - 2003 7.3L Power Stroke Diesel 8 12-14-2016 01:34 PM
Starter bolt size Badboy4wd 1999 - 2003 7.3L Power Stroke Diesel 12 10-16-2016 11:16 AM
Starter failure. 2 bolt & 3 bolt will interchange.(EDITED) dn29626 1999 - 2003 7.3L Power Stroke Diesel 3 08-07-2015 09:35 PM
Starter bolt size, 70 f-100 390 engine 70-360fe 1967 - 1972 F-100 & Larger F-Series Trucks 3 11-11-2013 10:00 PM
Loose starter but bolts are tight. SC_Dave 1999 - 2003 7.3L Power Stroke Diesel 13 04-26-2013 06:39 PM
Tags
1997, 2000, 2003, 351m, bolt, bolts, f150, ford, missing, motor, mounting, replace, size, starte, starter, strter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
