Runaway temp on a 460
I did a 460 swap recently and am having trouble getting the temp to stay normal. What happens is when driving around keeping a steady speed the temp is fine. When idling it's fine. Under hard acceleration and towing, fine. But, when I am slowing down, say, getting off the interstate, the temp goes through the roof. I have seen temps as high as 240 within 45 seconds of slowing down. If I rev it up a little the temp drops back to normal. I have tried 2 themostats, had the rad cleaned out, changed the fans out. What are your thoughts? Is it possible the water pump is cavitating? Bad pump? Bad timing cover? Any help is appreciated...
Tomc750
10-22-2014 09:39 PM
fasthauler
22
03-23-2013 01:29 PM
Robertw332
06-30-2003 08:31 PM
