2007 Fusion V6 engine clicking? - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 02-05-2010, 05:36 PM
fordtruckman's Avatar
fordtruckman fordtruckman is offline
fordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to behold
So I was sitting in a drive through earlier today and noticed that my engine was making a clicking noise, I thought maybe it was the car behind me so I shut my car off and the sound stopped. Turned it back on and there it was again. Anyone on here with a V6 Fusion have the same noise? Or if anyone on here that knows about the 3.0L V6 could help that would be awesome.
Old 02-05-2010, 06:00 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Might be your injectors. I have the same 24V 3.0L in my Taurus and it's an awesome engine. 110,000 trouble free miles.
Tim
Old 02-05-2010, 08:19 PM
Phinxter's Avatar
Phinxter Phinxter is offline
Phinxter is gaining momentum as a positive member of FTE.Phinxter is gaining momentum as a positive member of FTE.
do you have a warranty? If so I would have it checked.
Old 02-05-2010, 08:28 PM
Nahh I'm out of warranty but I started it again earlier after it had been sitting for a little while and it didn't make the clicking noise. So I'm not sure what the deal is. I suppose I could take it to the dealership since there isn't really any local mechanic that I trust but I can only imagine how much the dealership would charge me. Ugh I get sick just thinking about it.
Old 02-05-2010, 09:10 PM
Phinxter's Avatar
Engine - Ticking Noise From L/H Cylinder Head
Notes
TSB 08-3-10
02/18/08
CAMSHAFT TICK NOISE - 3.0L 4V ENGINE ONLY
WITH EXHAUST CAMSHAFT DRIVEN WATER PUMPS
FORD:
2005-2007 Five Hundred, Freestyle
2006-2007 Fusion
2006-2008 Escape
LINCOLN:
2006 Zephyr
MERCURY:
2005-2007 Montego
2006-2007 Milan
2006-2008 Mariner
This article supersedes TSB 07-13-10 to add a production fix date.
ISSUE
Some 2005-2007 Five Hundred, Freestyle, Montego, and 2006-2007 Fusion, Milan, 2006 Zephyr, 2006-2008 Escape and Mariner vehicles built 1/17/2006 thru 5/31/2007, equipped with the 3.0L 4V Duratec engine with exhaust camshaft driven water pumps may exhibit a ticking noise from the left bank cylinder head with the engine at normal operating temperature.
ACTION
Refer to the following Service Procedure to identify and resolve the engine ticking noise.
SERVICE PROCEDURE
To diagnose, with the engine running and warm (normal operation temperature), using a mechanic's stethoscope, determine if ticking noise is coming from the left hand exhaust camshaft at cylinder number 6 (Figure 1). If ticking noise can be verified, refer to the following Service Procedure.
For 2008 Escape and Mariner, check the date on the LH cam cover engine label. If the engine build date is 5/16/2007 or before, refer to the following to identify and resolve the engine ticking noise. For engines built after this date, this procedure does not apply; refer to Workshop Manual (WSM), Section 303-00.
For 2007 Fusion and Milan check the date on the front cover engine label. If the engine build date is 5/9/2007 or before, refer to the following to identify and resolve the engine ticking noise. For engines built after this date, this procedure does not apply; Refer to WSM, Section 303-00.
1. Remove the left hand camshaft cover. Refer to WSM, Section 303-01 of the appropriate manual.
2. Rotate the engine clockwise until the cylinder number 6 exhaust cam lobes are pointing up and the valves are fully closed.
3. Remove all left hand exhaust cam caps individually and reinstall them finger tight.
4. Torque bolts in sequence as shown in Figure 2, to 72 lb-in (8 N.m) excluding cam cap number 4L camshaft cap.
5. Using a screw driver positioned on each side of the top of cam cap number 4L (Figure 3), apply hand pressure and shift cam cap number 4L toward the exhaust side of the cylinder head.
6. While holding cam cap number 4L in the shifted position, torque the fastener number 9 (inboard) first, to 72 lb-in (8 N.m) then torque fastener number 10. (Figure 3)
7. Install the left hand camshaft cover. Refer to appropriate WSM, Section 303-01.
8. Fully warm the engine to verify the repair.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
080310A 2005-2007 Five 1.2 Hrs.
Hundred/Freestyle/Montego
3.0L DOHC: Remove The
Exhaust Camshaft Caps
And Reinstall Following
The Service Procedure.
Includes Time To Verify
Concern, Remove And
Install Camshaft Cover
And Verify Repair (Do Not
Use With 6250AL, 6584AL)
080310A 2006-2008 Escape/Mariner 1.4 Hrs.
Concern, Remove And
Install Camshaft Cover,
080310A 2006-2007 1.2 Hrs.
Fusion/Milan/Zephyr 3.0L
DOHC: Remove The
Concern, Remove And
DEALER CODING
CONDITION
BASIC PART NO. CODE
6250 07
Old 02-05-2010, 11:32 PM
Thanks Phinxter, I feel a better knowing that this is a known issue. Although the procedure for fixing it kinda freaks me out. With TSB's you still have to pay for everything right? If so I wonder how much it will end up being to have this fixed.
Old 02-06-2010, 03:24 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
If you go to a dealership and explain the issue, they should fix it for free, despite the vehicle being out of warranty (given there is a TSB on it)
Old 02-06-2010, 05:17 PM
Phinxter's Avatar
Quote:
well first your engine must meet the criteria. For me it looks rather simple to fix, my post didn't include the pics but I can send them to you if you want to try fixing it yourself. Yes if your out of warranty you got to pay for it but that is up to your dealer, I'll admit I aint no Ford tech so I have no idea how they handle something like this. Warranty time is 1.2 hrs but they may want to charge a diagnostic fee on top of that and even increase the repair time maybe. I would guess maybe 2 Benjamins at most.
Ford Fusion Hybrid Ranked Best Green Car for Your Greenbacks DerekShiekhi General Automotive Discussion 0 02-09-2016 05:46 PM
2006 Ford Fusion advice tractorfan Car/truck Buying Advice 0 06-04-2014 09:29 PM
Question about speakers Rusty_S Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 4 05-04-2014 10:02 AM
Long Term Test! 2012 Fusion 3.0-6, 6spd quaddriver Ford vs The Competition 3 04-14-2012 06:48 AM
How does A plan work??? Still Smoking Car/truck Buying Advice 6 08-18-2009 11:20 PM
Tags
2007, 30l, 4v, 71310, camshaft, clicking, dohc, duratec, engine, ford, freestyle, fusion, hundred, noise, review, tick, ticking, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
