Brake lights?....Really sensitive/flashing?
Hey all...I have been having problems with my brake lights being really sensitive. Like when i put pressure on the pedal and then release a tiny bit of pressure the lights shut off and then back on with barely any movement of my foot. I know this happens when you first start to brake and you are barely putting any pressure on the pedal, but this is happening to me after the pedal is most of the way down or all the way down. My cruise also doesn't work. I know the cruise is linked to the brake lights but what would be making my lights so sensitive to pedal pressure? is there a brake sensor that might need to be replaced? Thanks
The sensor (BPA) on the end of the master cylinder is a redundant brake switch that deactivates the CC. The brake lights are turned on/off with a sensor (BOO) connected to the brake pedal under the dash.
The BPA has been recalled due to causing fires. You may be able to get e new one from the the dealer....free. About $25 if need to it. This may solve both of the problems.
Let's not confuse him too much yet. The most common cause of this exact problem is the bad early type brake booster and misadjusted brakes. The booster isn't holding enough pressure back on the brake pedal to keep the light on.
I think the cruise is a separate problem.
Easy way to check this is to listen for air sucking. In it's final death throws you will hear that when you push the brake and hold it.
Also the pedal feels mushy and goes down a lot farther than it should.
It would be real easy to stick your head under there and with the engine running, door chime unplugged so you can hear , push the pedal down just enough to click the switch on. Does the pedal shaft go into the booster more and release the switch?
Bad booster if so. There is a Ford service bulletin explaining this exact problem.
You still need to adjust the rear brakes though. 90 % of the guys on this forum don't have them adjusted right I'd bet.
RRranch, I have to admit your correct on this. I looked and the switch is on the rod, a pressure thing. Good call and learning experience for me. Guess I always thought it was just a on/off switch on the brake peddle, like the IVS ... wrong.
Tried to rep ya but need to spread it around more.
on
1 Post
The adjusters do suck on these trucks. I'va never worked on one yet that stayed adjusted right on it;s own.
The switch on the pedal is just a simple on off switch but if the brake booster isn't holding then the rod slacks up as tou are holding the pedal down and it's a constant on off thing on the switch. I just went through this on my 94 again. First time for me since I worked at Ford. I put a new booster on it from my 97 and problem solved. Mine was real messed up with the electric brake controller too. Since it's activated by the brake lights, it was turning on and off too when I stopped and would never hit full pressure on the trailer brakes. A little scary sometimes.
Pipeliner_86
12-03-2015 07:01 AM
thompsdw
04-29-2012 08:58 AM
lottscreek
11-07-2005 08:29 PM
