intermittent wiper wiring diagram - Ford Truck Enthusiasts Forums
Old 02-05-2010, 01:05 AM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.RCrawler is gaining momentum as a positive member of FTE.
Need a wiper diagram for a '79 with intermittent.
Thanks,
Jason
Old 02-05-2010, 03:15 AM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Here you go...
1978-1979 Wipers, washers, heated backlight, Instrument panel illumination, and Radio dial illumination diagram.
http://i447.photobucket.com/albums/q...scan0001-1.jpg
Old 02-05-2010, 11:19 AM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is online now
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
I dont mean to hijack, but i grabbed the switch and delay box from my 89 donor truck, and was wondering if i can make this work with my 79 non delay wiper motor? Havent dug into the dash yet as mine is an a/c truck just wondering if anyones knows off the top of thier head.
Old 02-05-2010, 11:46 AM
2HI2CU's Avatar
2HI2CU 2HI2CU is offline
2HI2CU is starting off with a positive reputation.
I used the switch and delay box out of an 84 Bronco in my 77,and it works perfect with the factory non delay wiper motor.
Old 02-05-2010, 12:19 PM
1977f250 1977f250 is offline
1977f250 is starting off with a positive reputation.
Harryboxnoogle I know a 80 to 86 will work on your 79 never tried a newer one than that. You will just need to change the washer pump wire around but it will work. Only thing other than that is the shaft is about 1/4" longer but installed hard to notice that.
Old 02-05-2010, 12:28 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
answer for the wiring using later model stuff is in one of these. I have all 3 saved as "intermitent wipers" and I'm not gonna look through all 3 for you to determine which it is.
http://www.ford-trucks.com/forums/83...nt-wipers.html
http://www.ford-trucks.com/forums/70...onversion.html
http://www.ford-trucks.com/forums/90...nt-wipers.html
Last edited by ChaseTruck754; 02-05-2010 at 12:30 PM. Reason: cleaning up URLS from copy/paste
Old 02-05-2010, 01:20 PM
1980-1991 F-series and Bronco intermitant wiper switches and govenor modules are a direct swap.
If you change the washer pump wire around, it will also work 1973-1979.
Old 02-06-2010, 12:41 AM
RCrawler's Avatar
Thanks again. That'll help.
Jason
Old 02-06-2010, 10:02 AM
Kalve's Avatar
Kalve Kalve is offline
Kalve is starting off with a positive reputation.
yea same here thanks I am looking to do the same thing add delay wiper to it.
intermittent wiper conversion prima4682 1961 - 1966 F-100 & Larger F-Series Trucks 18 01-22-2016 09:21 AM
Intermittent wipers question jsnbuck 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-09-2012 09:34 PM
Intermittent Wipers? Blue and White 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-01-2012 05:34 PM
94 intermittent wiper problem - help gopedal Ranger & B-Series 2 06-29-2009 08:53 AM
Front Wipers 94 Explorer Mike in RI Explorer, Sport Trac, Mountaineer & Aviator 21 07-12-2004 10:20 AM
Tags
1938, 1989, 2002, 4wd, delay, diagram, diagrams, f150, f250, ford, motor, schematic, truck, wiper, wirind, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
