Shaking and smell fuel - Ford Truck Enthusiasts Forums
Old 02-04-2010, 11:30 PM
kcv kcv is offline
kcv is starting off with a positive reputation.
1999 Ford Explorer 6 cyl Two Wheel Drive Automatic 135000 miles
My Explorer have check light on 2 weeks ago, and the error code
P0171 and P0174 . However, the SUV still run normal
Yesterday, it became shaking and lost power then the check engine light blinking and smelling gas from exhaust smoke. Scan code again. I got P0171 and P0174 and P0306
I bring to a shop to check. They said MIGHT be the issue with intake manifold and they want $500. Is that reasonable? Any other possible cause the problem? What I should check?
Thanks
Old 02-05-2010, 06:47 AM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Welcome to the forum! Try using the "Search this forum" feature from the forum main page for keyword "P0171". You'll find that these codes have been addressed several times on this forum along with some good descriptions on how to check the PCV elbow, intake manifold, and comments regarding the DPFE. Since you have the code for both banks of cylinders the issue is likely to be something related to both banks such as the PCV elbow. An intake manifold/gasket would likely start out impacting only one bank.
The P0306 is a misfire code for cylinder #6. If it's been awhile since the spark plugs and wires have been changed the source of the P0171 and P0174 may have caused a plug to foul. Or you might also have a fuel injector that is not functioning properly contributing to the raw fuel smell.
If you plan to keep the vehicle for awhile you might start with a tune up (spark plugs, wires, fuel filter, air filter) since that is routine maintenance and could solve all three issues, but I suspect you'll still find yourself searching for the other issues addressed for P017x codes.
-Rod
Old 02-06-2010, 09:12 PM
kcv kcv is offline
Thanks Rod
I have replace plugs and wires. No more gas smell and the engine better, the idle still not smooth (some time shaking). Should I replace the PVC valve or replace the intake manifold seals?
Kevin
Old 02-07-2010, 08:12 AM
shorod's Avatar
Have you cleared the diagnostic codes and checked to see if the P0171 and P0174 came back? It would be difficult over the Internet to distinguish between the PCV and the manifold gasket just from the symptoms and codes. Determining which is required will require inspection. I would expect the shop has the capabilities to diagnose which is the more likely culprit, or if nothing else, which one it is not.
-Rod
Old 02-07-2010, 07:55 PM
kcv kcv is offline
I have driven the E about 60 mile today. Here what I see so far:
  • The check Engine light is OFF. Is the code available when the like OFF?
  • The idle is shaking.
  • Power is still losing (but not feel much shaking). I can speed up to 60 mile but not quickly accelerate like before.
  • No more fuel smell
  • So time heard straight click, click .... noise (about 5 minutes) seem like from valve on from the back of the engine. and then it gone by itself
Thanks
Kevin
Old 02-08-2010, 10:13 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
My brother just had lean codes on his Aerostar. Didn't get on it right away and ended up costing him some valves. $500 is very reasonable.
Old 02-08-2010, 12:53 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Thanks
Kevin
The ticking may be associated with a plug misfiring, that would explain the residual shake and lose of power.
I would remove all the "NEW" plugs, use a thread chaser(particular attention to #6, close to firewall, driver side), regap the plugs, use anti seize, reinstall plugs. Check the wires, replace if defective.
Old 02-08-2010, 12:57 PM
shorod's Avatar
Pending codes could still be gathered even if the Check Engine Light (CEL) is not currently on. Sounds like you still have a vacuum leak or ignition misfire. You might want to make sure none of the spark plug wires have come loose from the coil or plug.
-Rod
Old 02-08-2010, 10:22 PM
kcv kcv is offline
Thanks All
Here what i just try:
Remove spark plugs 1, 4, 5, and 6 (2 other need to take off the wheel). #1, #4 and #5 are white like new. #6 is black and fuel wet.
Install the plugs back, replace #6 wire still same issue (shaking and lack power)
Disconnect #6 from the coil, nothing change like #6 does not affect any thing
Lift the #6 wire close to the #6 coil, I have seen sparks between the coil and the wire. Is that mean the coil OK?
Inspect vacuum lines, I did not found any thing
What should I do next? replace coils, PCV valve, fuel or replace intake manifold gasket?
Cheers
Kevin
Old 02-09-2010, 06:22 AM
shorod's Avatar
I suggest you remove the plug from cylinder #6 and clean it, then swap it with a plug from another cylinder. See if the misfire follows the plug or the stays on cylinder #6. If if follows the plug then you probably have a bad plug. If it remains on 6, then try swapping the spark plug wire with another wire of similar length.
-Rod
Old 02-09-2010, 09:47 AM
kcv kcv is offline
Thank Rod
I have swapped the plug and wire. The misfire stay the same plug #6.
Cheers
Kevin
Old 02-09-2010, 01:08 PM
shorod's Avatar
If the misfire stays on cylinder #6 and the spark plug and spark plug wire have been swapped with different cylinders that would suggest you either have a coil issue, a compression issue, or a fuel injector issue. Since the plug was wet with fuel like you mention in post #9 above, the injector is probably not the issue unless it's stuck open all the time.
You should use a spark tester to confirm that there is spark to the plug for cylinder #6. You don't want to just let the plug wire arc to the engine or body, that is hard on the coil.
-Rod
Old 02-10-2010, 11:08 PM
kcv kcv is offline
Finally, I think it is time to get a new car.
I have changed intake manifold gasket and PCV valve. The car have improve power and vacuum, but still shaking . I still heard some metallic noise from the engine as mentioned in previous post and then the noise gone. I let the car in idle for 30 minutes and then took drive test about 10 miles. The power have some improve but not as it was. When driving into garage, I heard strong noise like some think broken from the engine and the E totally dead. Try start again but no luck. Inspect engine oil from the oil cap, I have seen some metal powder in oil and the cap I think some think have broken in the engine or the head. This problem is over my hand.
Thanks All for help.
Kevin
Old 02-11-2010, 06:58 AM
shorod's Avatar
Ouch, sorry to hear that.
-Rod
96 f-150 codes p0171, p0174, p0420 James Bibb Ford Inline Six, 200, 250, 4.9L / 300 4 05-27-2012 06:24 AM
Error Codes: P0171, P0174, P1151 psu152 Explorer, Sport Trac, Mountaineer & Aviator 5 05-26-2009 05:03 PM
'98 Expedition -six OBD codes D-man13 1997-2006 Expedition & Navigator 3 09-28-2007 12:33 PM
98' XLT CEL P0171 & P0174 Codes njxlt 1997-2006 Expedition & Navigator 1 09-16-2006 10:15 AM
Pulled code P0171 & P0174 on mazda mvp ??? oojbearoo General Automotive Discussion 6 03-01-2006 12:45 PM
Tags
1997, 2002, check, engine, explorer, ford, fuel, gas, light, mil, p0171, repair, shaking, smell, smelling, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
