2000 ford explorer no 1st gear - Ford Truck Enthusiasts Forums
Illinois Chapter Join Chapter Leader: KOESTNER
Old 02-04-2010, 10:14 PM
tanker2008 tanker2008 is offline
tanker2008 is starting off with a positive reputation.
hi guys great forum i'm new here and thought i could get some reasonable suggestions on my trans problems no 1st gear or shifting from 1st to 2nd automatically seems to be stuck in 2nd when you start out very slowly trans seems to slip or shutter until it picks up momentum at 35 to 40mph you can shift manually to drive and continue accelerating no overdrive when button is pressed or will not downshift automatically but you downshift maually to second and it will drop down check engine codes show po743,po755,po760,po765 had the normal explorer idiosincrisces most of it's life but nothing ever like this.... has 112,000 miles fluid full, not burnt,nice reddish color,2000 ford explorer xls 4.0 4wd 5r55e thanxxx.. brian <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
<!-- controls -->
<!-- controls -->
Old 02-05-2010, 06:57 PM
skullcash's Avatar
skullcash skullcash is offline
skullcash is starting off with a positive reputation.
what kind of transmission do you have? that will help me to help you. lol
Old 02-05-2010, 10:16 PM
2000 explorer no 1st gear
ford 5r55e 5 speed transmission
Old 02-07-2010, 01:41 PM
skullcash's Avatar
OK well it sounds like you have a electrical problem with one of your sensors! i have come a crossed it on the AOD "E" transmission. but does it engine brake in the manual low gears and also does reverse work good? I've noticed that the band on the reverse drum might cause some problems but i don't think your transmission would have that problem but i might as well ask! what does your torque converter stall to? that will also help me with the diagnosis!
Old 02-07-2010, 02:14 PM
good questions thanxx for checking out my post yes while driving in D mode at 35mph if you drop down manually into 2nd there is engine braking the other day i spent a good while up and down my driveway going from reverse to drive and 2nd there are no issues there... also if your driving in 2nd gear about 25mph and you manually shift down into 1st the engine does not brake or trans does not shift down thannnxxxx...brian
2000 ford explorer no 1st gear tanker2008 Clutch, Transmission, Differential, Axle & Transfer Case 3 04-14-2010 12:25 AM
2000 ford explorer no 1st gear tanker2008 Explorer, Sport Trac, Mountaineer & Aviator 0 02-04-2010 10:12 PM
35's on 18x10s 4.5" backspace 2.5 level kit? JBlrmker 1999 to 2016 Super Duty 13 01-13-2010 03:37 PM
Symptoms of a bad EVP (EGR Valve Position sensor) THE BLUE HEAP 1968-2013 Full Size Vans 1 12-25-2009 09:18 AM
2barrel or 4barrel? 1eyedjack Ford Inline Six, 200, 250, 4.9L / 300 65 04-24-2009 03:58 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
02, 1st, 2000, 4x4, 97, aode, automatic, explorer, ford, gear, no, reverse, slips, sticks, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
