How do I tell if my 97 Ranger is 2 or 4 wheel ABS?
Hey everybody,
I have a 1997 Ford Ranger Splash. 2wd, 5-speed, V6, 4.0L. It has 150,000 miles and it needs front brake pads and rotors.
I did the brakes myself 6 years ago and had the rotors turned, and I think that this time I am going to need to replace the rotors.
I bought a set of Wagner ThermoQuiet pads (Those are the same brakes that I put on 6 years ago), but when I was at Advance Auto Parts, they asked if my truck was 2 or 4 wheel ABS. That determines what kind of rotors I get.
How am I able to tell if my truck as 2 wheel or 4 wheel ABS?
Any help would be greatly appreciated!
-Joe
-Joe
It should be the 2 wheel ABS setup. Be sure to take an old rotor with you to match up to the new ones you purchase. There are multiple offerings available. At least I found that to be the case with my 03. If there is ABS on the front the rotors will have a trigger ring on the rotor for the ABS sensor.
kittyhawk
1999 to 2016 Super Duty
07-18-2012 05:01 PM
cjcathey2002
11-29-2009 07:33 AM
