Dash board lights
Dash board lights
i posted a question about replacing dash lights, last week. only recevied replys from others wondering the same thing. i lost the lights to my fuel and oil pressure gauges on the left side of my dash, 2006 f350 diesel auto trans. wondering if anyone has replaced these before, if it can be gotten from under the dash. is it still a small bulb? or do i have to look forward to removing the whole gauge panel? Any help would help a number of us
They are regular bulbs. Small, cant remember the # off hand but a parts store should have it if. On the back of the cluster you will see small black thumbscrew type caps. Twist and pull them out, they are the bulb holders. Do yourself a favor and replace them all while you have it apart. Go to a parts store and get just the bulbs, they just pull out and push in to the caps. If you go to Ford they will sell you the bulbs in new caps at about 4 bucks a piece.
I just replaced the bulbs in my 01, don't know how much applies to your trucks but mine took 5 #194 bulbs. The cluster had to come out but all in all it only took 15 minuntes start to finish.
I used the instructions here to get mine apart
2004 F250 LED Dash Lighting
This is for doing an LED upgrade but I just used the directions because he has lots of pictures and I'm a little slow.....
Good luck
Good luck
kegger66
09-01-2016 02:02 PM
59 BL JNS
07-12-2016 03:57 PM
