Sound system upgrade. - Ford Truck Enthusiasts Forums
Old 02-04-2010, 08:07 AM
chayes01's Avatar
chayes01 chayes01 is offline
chayes01 is starting off with a positive reputation.
I'm wanting to upgrade the sound system in my crewcab and would like to find out what others have done and maybe how they'd do anything different. I'd like to add speakers in the rear but don't want to have them below the back seat. I have the XL package so the inside door skins don't have the speaker grilles. Do the rear doors have speaker openings in the frame for the XLT and King Ranch packages? Are the factory speakers standard 6X9's or are they an odd size? Any tips would be helpful.
Old 02-04-2010, 09:03 AM
03_PSD 03_PSD is offline
03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.
If I remember correctly the front and rear speakers are 6x8's and you can add subs behind your rear seat. I have upgraded to pioneer head unit and speakers front and back and 3-8" Kicker L7's in a home-made box with a 1200 watt amp pushing those. Sounds pretty good and clear.
Old 02-04-2010, 09:06 AM
makomaker's Avatar
makomaker makomaker is offline
makomaker is gaining momentum as a positive member of FTE.makomaker is gaining momentum as a positive member of FTE.
I have a Pioneer head as well, RF 6x9's all the way around, RF 10" sub shallow mount, and Alpine PDX5 amp. I think it sounds
Old 02-04-2010, 09:11 AM
jeff7825's Avatar
jeff7825 jeff7825 is offline
jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.
The stock speakers are not in the rear doors, they are in the pillar behind the door. Check for a speaker grille there. The stock speakers are 6x8.
Old 02-04-2010, 09:18 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
I thought the stockers were 5x7s, but 6x8s would fit. I'm about to start working on mine as well, and my plans for the sub is to replace the middle seat (I have the 40/20/40 front seat) with a box so I can mount my arm rest on it in the stock position. Mike (Tenn350PSD) did that on his -- looks nice!
Old 02-04-2010, 09:47 AM
DieselBeast01's Avatar
DieselBeast01 DieselBeast01 is offline
DieselBeast01 is gaining momentum as a positive member of FTE.
Ive got a panasonic in dash DVD with navigation and a bunch of other stuff that I don't need, but i got it for a good deal. As far as speakers go, I have Kenwoods all the way around and a 12" Kicker L7 Solo-Baric powered by a Kicker ZX1000 amp behind the back seat. Its plenty loud enough for me. I hardly ever turn it up as loud as it will go.
Old 02-04-2010, 09:55 AM
N V US Lawn Care's Avatar
N V US Lawn Care N V US Lawn Care is offline
N V US Lawn Care is gaining momentum as a positive member of FTE.N V US Lawn Care is gaining momentum as a positive member of FTE.
who needs a stereo with that kool a$$ diesel rumble...drone...lol...i just have a JVC head unit and 6x8's in all locations...i do want to add a small sub for some bass, those 6x8's are basically flat sounding...
Old 02-04-2010, 11:01 AM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
WA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to all
I also have a JVC head unit with Infinity 6x8's up front and Kicker 6x8's in the rear. I also have an Infinity Basslink 10" sub. Sounds good. I have a couple of Alpine amps I need to install to power the 6x8's.......one of these days...........
Old 02-04-2010, 01:10 PM
Mike Allen's Avatar
Mike Allen Mike Allen is offline
Mike Allen is starting off with a positive reputation.
I had to replace my stock system early on (about 4 years ago). The rear speakers are located in the pillar behind the rear seats. I am running JL Audio component speakers with crossovers in the pillar and front doors. I opted for twin JL Audio 10" sub enclosures that fit behind the seat very nicely. I have a Kenwood headunit with a JL Audio 150W per channel Mono for the subs and an Infiniti Reference Series amp for the components.
Amazingly, the amps, crossovers and wiring fit under the rear seat very nicely mounted on a peice of MDF. The only clue I have a kicka$$ system is the Kenwood head unit and tweeters on the door. Otherwise very stealth.
Oh yeah copius amounts of Dynamat in the door and behind the speakers keeps the sound nice and tight.
Old 02-04-2010, 02:49 PM
caseydudem's Avatar
caseydudem caseydudem is offline
caseydudem is starting off with a positive reputation.
I am invisioning(All I can afford) what I could do to my stock system. The factory put in 6x8s, but is it pretty easy to stick a 6x9 in?
Is the head unit a double din size?
Old 02-04-2010, 03:14 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke 02GrayPowerStroke is offline
02GrayPowerStroke is gaining momentum as a positive member of FTE.
I am thnking 6x9's will not fit. But double check that. Try Crutchfield.com
Old 02-04-2010, 03:55 PM
jeff7825's Avatar
No, but you can fit a double din head unit with minor trimming of the radio opening.
Old 02-04-2010, 04:10 PM
caseydudem's Avatar
Quote:
I didn't think they would fit exact, but I have put some 6x9s in places of 6x8s with very little trimming. I was hoing that someone else had tried it and knew how much trimming was required. I did look at Crutchfield but they just say that factory speakers are 6x8. Thanks
Old 02-04-2010, 04:11 PM
caseydudem's Avatar
Quote:
Have you done this, and do you have any pics showing what you did or how it turned out? Thanks for the info
Old 02-04-2010, 04:57 PM
Texas Outlaw's Avatar
Texas Outlaw Texas Outlaw is offline
Not a liberal...
Texas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant future
Alpine head unit here with Alpine 6x8s, two 100w Infinity 10" powered subs and a 1600watt, four channel, Power Acoustik amp under the back seat.
It sounds SWEEEEET.
1993 F150 speaker replacements woodsnake Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 02-11-2016 06:22 PM
how to replace doorspeakers and wiring aslowdodge Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 10-26-2015 06:28 AM
How to upgrade the stock sound on an Aerostar KhanTyranitar Aerostar 51 03-23-2015 06:51 PM
Speaker problem srb1194 2004 - 2008 F150 0 08-15-2014 08:07 PM
what size speakers? 1 Excursion camper Excursion - King of SUVs 29 11-19-2013 02:20 PM
Tags
10, basslink, duty, f150, f350, ford, infinity, mount, ranger, sony, sound, super, system, truck, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
