Pinion Angle - Page 3 - Ford Truck Enthusiasts Forums
Pinion Angle
  #31
Old 02-08-2010, 11:23 PM
9.ford.5's Avatar
9.ford.5 9.ford.5 is offline
9.ford.5 is gaining momentum as a positive member of FTE.9.ford.5 is gaining momentum as a positive member of FTE.
okay then?
  #32
Old 06-16-2014, 09:05 PM
dregan4189 dregan4189 is offline
dregan4189 is starting off with a positive reputation.
im dealing with the same issue. pinion angle problems... im welding new perches to alter the angle. I have one major concern though my tcase!
I threw the angle finder on the flange and its sitting at .5* angled up not down. shouldn't it be at 90* or 0*?(however you want to look at it)
I just don't want to do all of this and find more catastrophic issues.
is this a major issue I checked motor and tranny mounts and all seem to be intact with basic visual inspection
Pinion angle advice Blinker Fluid 1967 - 1972 F-100 & Larger F-Series Trucks 18 04-26-2014 09:34 PM
front axle pinion angle? benmoderow 1973 - 1979 F-100 & Larger F-Series Trucks 32 02-23-2010 10:14 PM
Setting Pinion Angle 2losteve 1948 - 1956 F1, F100 & Larger F-Series Trucks 40 05-22-2009 12:09 AM
Pinion Angle scatgo 1994.5 - 1997 7.3L Power Stroke Diesel 15 02-11-2009 07:23 PM
9 inch pinion angle atccracing Clutch, Transmission, Differential, Axle & Transfer Case 3 11-02-2004 07:39 AM
Tags
2wd, 302, 5, 70, angle, anglef150, bronco, case, dana, driveshaft, f150, ford, ii, optimum, pinion, transfer, w250
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
