Ask the engineer for the new 6.2l gas engine!
#526
If all of you are right, in that this 6.2L should have been a 4-valve design in the first place, then it is merely a marketing reason for not doing so to begin with. I hope not, being that I purchased a 2011 6.2L. However, vs my 08' 5.4L, I am very happy. Although milage while plowing is under 11 now. And, if the Ford engineer comes back my guess is that he will circmuvent the question. Again, I am pleased with the engine in a heavy truck. My gripe is the hop-shake which GM is marketing. How about that Mr. engineer? My 2011 hop-shaked into the next lane on a bad city road once. And in general, it is the only gripe, other than mpg, in the 2011 F250, relative to F150s.
#527
Uhhhhh,hop-shake which WHO is marketing?? Hop-shake? On the F250? And all this time I thought FORD marketed the F250.... And I STILL don't know what a hop-shake is......
#528
I get that hop shake also, sure wakes you up on a rough highway. Tracks well on the dirt road, but when I hit a rough spot on the highway it wants to change lanes.
2011, F250, King Cab, LB, 6.2L, 6 weeks 4 days in shop so far.
#529
GM specifically markets hydraulic shocks and dif leaf springs for a smoother ride. Don't know if it works though. Just marketed that way.
#531
GM trucks have IFS, that is why they do not have a problem with 'hop-shake' or bump-steer.
#532
Even better! In my last post I thought it was the REAR suspension that was at fault for these problems, as a too-stiff rear setup CAN also cause aform of bump-steer or "hop-shake"; or at least I thought it could. Thank you!
#533
If you want a truck the behaves like a car when empty buy a F150, If you want a truck with a heavy suspension so it can haul a load buy a Super Duty. Any HD truck will jump around when empty but they sure ride nice and stable when hauling or pulling a load.
Denny
Denny
#534
The thing is any truck with an SFA, Ford, Dodge, Jeep, old GM, will have 'bump-steer'. Bump steer happens when the axle moves in relation to the chassis, and the angle of the pitman arm and drag link changes slightly. This causes a steering influence, so the vehicle will pull a bit to one side (usually to the right). as it hits a bump. IFS will not do this, as suspension deflection causes a change in toe-in, equal on both sides.
#535
Denny
#536
Well it doesn't look like the Ford engineer, Mike Harrison, is coming back anytime soon to answer questions. But, if you have a question you'd like to leave for him in case he returns, post it up. Otherwise, let's take the suspension debates, and / or debates in general to their own threads folks.
#537
Mike's the 6.2L engine guy anyways, isn't he? So I doubt he'd shed much light on any discussion other than those directly addressing the engine.
Still, it would be fun to have him back after a year of the engine's use by the public.
Too bad.
Mike
Too bad.
Mike
