power steering issue
Old 10-28-2016, 09:14 PM
Ted928's Avatar
Ted928
Ted928 is offline
I recently changed my PS lines and front struts. Since then the assist is not correct. The level of assist is not constant. When cold it is worse - feels like steering is binding. After it is fully warmed-up it steers much better but still not perfect. I have worked it lock to lock and I see no signs of air.
All I can think of is when I started it after changing the lines, maybe I damaged the pump when I first started it. The reservoir had been full but it made noise until I could refill it. Maybe the 20sec of partial dry running damaged the original pump????? Any suggestions?
Old 10-29-2016, 07:23 AM
Ted928's Avatar
Ted928
Ted928 is offline
I did not have the truck realigned. Does strut replacement require realignment?
Old 10-29-2016, 09:47 AM
Ted928's Avatar
Ted928
Ted928 is offline
I found the problem thanks to searching this forum on "hard steering". The problem was the steering column - the two knuckles. Soaked with WD40 and then covered with lithium spray grease and steering is fine now.
The problem was caused by my previous repair. When I was replacing the steering lines I saw the knuckles and sprayed them (not sure if it was WD40 or PB blaster). Not a good idea - a real oil and grease are needed.
Brandon150
2009 - 2014 F150
13
05-12-2017 09:20 AM
derek0525
24
06-25-2016 07:22 PM
Gatrucknut
01-01-2011 05:43 AM
keithmcintosh
02-01-2009 01:51 PM
1949f1
12-11-2004 07:11 PM
Quick Reply: power steering issue
