IDI Timeing
IDI Timeing
What is the proper way to time an IDI? I did a search and couldn't find the procedure. What i did was removed the oil fill loosened the 3 8MM 8 point bolts loosened the 3 nuts on the pump and turned the pump counter-clockwise. and tightened everything back up. when i fired her back up with the advance on she had the "Powerstroke rattle" when i turned off the advance still had a little rattle but not a lot. first did i go too far and 2 how long should the advance be on before it goes off .
maybe somebody could create a Tech Guide for some of the IDI specific maintenance and procedures.
Scott
Scott
