Aerostar Ford Aerostar
Rear seats In cargo Van?
Old 02-03-2010, 10:22 AM
illenema's Avatar
illenema
illenema is offline
Hello. I have a 95 stubby cargo van, can a rear bench seat be added as it looks like there no way to bolt it down, Local yard has a selection of aerostars and seats I have never seen a seat back there
Old 02-03-2010, 03:12 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
You need to install the seat anchors into the floor. I haven't tried this before (never had the need), but check those wagons at your local scrap yard to see if the anchors canbe easily removed. Installing them in the van will require cutting, I'm sure.
Old 02-03-2010, 03:27 PM
illenema's Avatar
illenema
illenema is offline
Yes thats what i thought, like steel posts the seat locks on to. There were a couple of bench seats that looked like they just bolted to the floor, on mine there is Nothing doing there no holes nothing. I bought it for my magazine route looks like it will be used only for that. thanks for reply
Old 02-09-2010, 02:03 PM
Pablo-UA's Avatar
Pablo-UA
Pablo-UA is offline
i did it. easy to make. easy to weld in, but do all accuratly, measure distance between anchors on any passanger van, else they may not fit ore you will not put them to bed in long trip.
what will U do with windows and trim?
Old 02-09-2010, 05:18 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
I was going to say the more critical one would be for the rear bench, since that can interfere with the wheel wells. On my van, the two sets of anchor wells are lined up, so that you can move either bench straight forward or back. The only peculiarity I found was that when I installed a set of seat-beds I got from a scrap yard, they have a 2" gap between them when folded down. This tells me that there may be some variation in fore-aft spacing between the wells. The seat-beds came out of a shorty, and mine is an extended van, so maybe they put the rear bench a couple inches further back.
KCBS Smoker
WTB - Parts & other
08-26-2016 02:24 PM
kynnhoj
01-17-2016 10:46 AM
Paulford8
2009 - 2014 F150
36
01-03-2012 04:41 PM
CraigH-CA
15
08-29-2011 06:00 PM
goodwrench
05-05-2010 07:50 AM
Quick Reply: Rear seats In cargo Van?
